turbo water lines?
Old Aug 4, 2009 | 02:45 PM
thegatekeeper14's Avatar
Default turbo water lines?
anyone have pic of were they routed there water lines for there turbo, going in and out of. picss woulld be nice.
Old Aug 4, 2009 | 03:59 PM
04450r's Avatar
Default Re: turbo water lines?
mine were tied into the throttlebody when i got the car but im also curious as to a cleaner setup
Old Aug 4, 2009 | 04:52 PM
1992Si's Avatar
Water came from a "T" in the water line under the TB, return was to the block on the head.
Old Aug 4, 2009 | 05:08 PM
not bad but what, hoese under the throttle? and any cleaner routes? can i use rubber lines?
Old Aug 4, 2009 | 05:23 PM
1992Si's Avatar
T off one of the hoses from the water transfer tube.
I used rubber until it got close to the turbo. I think on a street engine you may want to wrap the rubber hose if it's close to high heat areas. Better safe then sorry on a hot day in traffic.
Old Aug 4, 2009 | 06:52 PM
huh, can u just yous brass barbed fittings for now?
Old Aug 4, 2009 | 07:05 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i dont have pics but i have a BnR fitting off the block then to the turbo. from the turbo to the bottom of the radiator
Old Aug 5, 2009 | 11:19 AM
any more pics!?
Old Aug 5, 2009 | 12:40 PM
cjordan's Avatar
i dont have pics but we sourced our water from the heater core
Old Sep 20, 2009 | 08:59 PM
IN VTEC's Avatar
IN
OUT
Old Sep 22, 2009 | 04:39 PM
a1320addict's Avatar
Old Sep 22, 2009 | 05:48 PM
IN VTEC's Avatar
I'd do it that way if I could on either one of our engines, but I use a block heater for mine and the other one uses a GT4294R with -8AN ports. I haven't seen anybody make a M28x1.00 to -8AN flare adapter for the block, so we're still using whatever available ports on the block, head, thermostat housing, intake manifold, etc.
Old Sep 22, 2009 | 06:03 PM
esedulerp5tenin's Avatar
do you guys know if the thread/hole size is the same for every turbo?
i can't find any barbed fittings for my t3super60 at home depot/lowes.
Old Sep 22, 2009 | 06:16 PM
LightningTeg's Avatar
Community Builder
Check garretts website. They have a drawing with dimensions on all they're turbos.
Old Sep 22, 2009 | 06:31 PM
IN VTEC's Avatar
Large frame turbos have a larger port size than the medium sized ones. I don't know anything about the small frame Garrett turbos or the Mitsubishi turbos, although they're probably M12x1.25.
Old Sep 22, 2009 | 09:26 PM
Si GUY99's Avatar
try 1 of these sites:
http://www.atpturbo.com/mm5/
http://www.anplumbing.com/
Old Sep 23, 2009 | 03:33 AM
scottdh20's Avatar
i did it the easy way. there is a couple water lines on your throtal body. i pulled the line from the back side of the iacv that runs to the back of the block or mani.... dont really remember.... but i pulled that out and ran a longer hose to the turbo and then a return line back to the block where the hose originally went..anyway i spent like 10 bucks at autozone for some rubber hose and like another 5-10 bucks for the barbed fittings for the turbo. i have daily'd it like this for over 6 months without any problems
g/l
Old Sep 23, 2009 | 09:54 AM
So, do it like we all used to before CNC made life easy, remove the factory freeze plug, drill, and weld a -8an male.
Old Feb 24, 2010 | 10:35 PM
h23vtec_dc2's Avatar
so does it matter which one is in and out? or they just work the same as long as you got a flow?
Old Feb 24, 2010 | 11:25 PM
slowman's Avatar
I took way too long
If I run water on my turbo I plan on getting this for the return flow:
http://www.go-autoworks-store.com/go12siraw6re.html
Old Feb 25, 2010 | 06:37 AM
vtechjunkie's Avatar
I like that set-up "invtec". Really easy to run the lines that way. But not as clean and hidden as the way "a1320addict" did it. I would probably use the block heater port as well.
Old Jul 6, 2010 | 06:21 PM
slammedobd1teg's Avatar
can you feed and return both to the radiator?
i want to feed it off the bottom of the rad and return it to the top.
i am having some slight overheating issues and i figured it would be best if the hot coolant from the turbo dont ever even go to the motor. if its possible i would like to both feed and return directly to the radiator.
GT500FTW
May 6, 2013 01:48 PM
RACEPAK
Feb 13, 2012 01:30 PM
h23vtec_dc2
Feb 28, 2010 04:47 PM
wade
Sep 18, 2004 01:47 PM
Integra of doom
Oct 11, 2002 10:19 AM
