Our Answer to running Coolant Lines
Old Dec 30, 2008 | 11:26 AM
morgan@synapse motorsport's Avatar
Default Our Answer to running Coolant Lines
We have an answer to the pita process of running coolant lines on your gt series turbo.
Our kit eliminates excessively long lines and does it in a simple manner utilizing a weld bung on the radiator and a block drain fitting we fabricate to except a -6 fitting.
The kit includes:
-6 Turbo Fittings
-6 Block Drain Fitting
-6 AN Fittings (Standard two 90's, one 45, one striaght)
-6 Black Braided hose
Old Dec 30, 2008 | 11:32 AM
rota92
Guest
Posts: n/a
Default Re: Our Answer to running Coolant Lines
ALAS! Something to end the endless water line threads lol
Old Dec 30, 2008 | 11:36 AM
tepid1's Avatar
Good idea guys!
I need one of those plugs for the block. Is it threaded?
Old Dec 30, 2008 | 11:41 AM
Yes, its a threaded plug that can be removed and re-used.
Old Dec 30, 2008 | 11:45 AM
cluelessmale's Avatar
looking sexy
Old Dec 30, 2008 | 12:18 PM
dpetro1's Avatar
Originally Posted by cluelessmale
looking sexy
looks very nice but hasnt B&R Fittings been doing this for a while? Nothing new or different about this setup
Old Dec 30, 2008 | 12:30 PM
rota92
Guest
Posts: n/a
I'm sure lots have been doing it for a while, much like a clutch company makes a twin disc then another does. But people don't question that now do they? lol
Old Dec 30, 2008 | 05:55 PM
narfdanarf's Avatar
My answer to running coolant lines was borg warner..haha
Old Dec 30, 2008 | 06:05 PM
1995Civic's Avatar
You beat me to it Ryan
I'm pretty sure that's why the thread states 'Our' Answer to running coolant lines
Old Dec 30, 2008 | 07:25 PM
HamiltonRex's Avatar
Old Dec 31, 2008 | 03:23 AM
Silva Bullit DC4's Avatar
Yeah they have, my friend just bought a kit like that from Brian at B&R for his new GT3076R.
Old Dec 31, 2008 | 04:42 AM
dpetro1's Avatar
true, i didnt mean to sound like a hater or anything. it just seemed that some people were praising them like is a brand new technology or something thats never been done before.
i think this is definitely the best way to run the lines. now can we start a poll for tapping the top or bottom of the radiator? i've heard arguements for both
Old Dec 31, 2008 | 11:31 AM
.adam.'s Avatar
best to tap the top, as to not bypass the radiator
Old May 13, 2009 | 07:12 PM
stiffdogg06's Avatar
Bump and PMed
Old May 13, 2009 | 07:35 PM
Mr.Death's Avatar
What about water flow. Water will only flow through the rad when the thermostat is open correct? So how is it supposed to flow through the turbo when the thermostat is closed? The rad is blocking flow till the thermo opens. Like when you bleed your coolant and you rad cap is off, the coolant does not flow till the thermo is open. . It looks killer and clean and all but is it effective???? An effective setup has coolant flowing through the turbo at all times.
Old May 13, 2009 | 07:37 PM
Schister66's Avatar
Man U FTW
Very nice, clean solution to this problem
Old May 14, 2009 | 01:34 AM
92civiceg9gsr's Avatar
Great idea!
Old May 14, 2009 | 05:40 AM
Running925's Avatar
thats a hell of a good point there.
Old May 14, 2009 | 05:47 AM
Alfa Turbo's Avatar
A better solution would include constant water flow and a resevoir higher than the turbo to act as a thermosyphon when flow has stopped at engine shut down. Otherwise water will just boil away and no longer be able to do the job intended.
Old May 14, 2009 | 05:52 AM
Turbocivic94's Avatar
I just did mine that way without welding. I run the drain to bottom **** on the radiator.
Old May 14, 2009 | 06:20 AM
portenio78's Avatar
Anyone know where I can find the right fitting that will fit a stock radiator drain hole?
Old May 14, 2009 | 06:35 AM
Isn't the turbo getting feed by the block coolant fitting from the back/front of the block and then DRAINS into the radiator? So would the thermostat even need to be "open" to have the coolant drain back into the radiator?
This is all new to me. I've always ran journal bearing turbos. So I am trying to learn some stuff.
What about running a bung at the top of the radiator to feed/drain the turbo and then one at the bottom to drain/feed
Old May 14, 2009 | 06:45 AM
It depends what radiator you have.
Old May 14, 2009 | 07:47 AM
Mr.Death's Avatar
All I;m saying is that coolant does NOT flow through the rad when the thermo is closed. We can all agree on that. The coolant would have to wait for the thermo to open to allow flow. I was thinking a good place for feed would be the front drain hole and for a return go after the thermo on the housing. This ensures that coolant is flowing at all times.
Old May 14, 2009 | 08:16 AM
When you say front drain hole, I'd assume you mean the big fitting on the front of the block. I have a d16y8 so it's on the back but same thing. I get where you're coming from. It's just I've seen A LOT OF ways to have this done LoL.
What about having a bung welded to the bottom of the radiator as a FEED source since there should always be coolant down there and then have another bung welded to the top of the radiator as a drain source? Would that work at all?
