Turbo Vacuum lines.
Guest
Posts: n/a
OK, the car is a soon to be turboed Integra. The vacuum line running from the FPR to the intake vanifold is currently t-d and has my boost gauge and vortech FMU feeding off it. I need a good vacuum source for my boost controller. Is it ok to run another T to it? Is it going to be all leached out?
If its a overload, any other suggestions for a vacuum line on the drive side of the engine compartment? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 »</TD></TR><TR><TD CLASS="quote">your boost controller could be hook up to the compressor if you turbo has it or a tube from the charge pipe correct me if im wrong</TD></TR></TABLE>
do you mean after you hook up one side of the boost controller to the top of the wastegate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00si5 »</TD></TR><TR><TD CLASS="quote">
do you mean after you hook up one side of the boost controller to the top of the wastegate?</TD></TR></TABLE>
yea thats right
yea thats right
don't forget if you need more vacuum sources you can use your cruise control vac line. (if you have/had cruise control)
Vacuum lines are pressurized system, I believe you can hook them up all together in a row and it wil still work. Companies like GE, mcmaster carr make a little box that has multiple ports on it to "T" everything off of this box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">Companies like GE, mcmaster carr make a little box that has multiple ports on it to "T" everything off of this box.</TD></TR></TABLE>
yeah you could spend that money and do that, but chances are you are broke like the rest of us after a turbo install so 35 cent t's will work fine. use the compressor, brake booster, and the couple sources on the intake mani. that should be all you need. good luck
