turbo vacum lines help?
Old Apr 20, 2008 | 08:59 AM
craig88crx's Avatar
Default turbo vacum lines help?
i was woundering where to tee off for my waste gate, bov, manual boost controller and my boost gauge.
Old Apr 20, 2008 | 02:16 PM
B20UnderPressure's Avatar
Default Re: turbo vacum lines help? (craig88crx)
well the blow off valve vac. line tees of your brake booster line before the check valve. The wastegate has 2 ports on it one on top and one on the side. The one on the side you need to run a vac line from there to the vac fittng on the turbo outlet if there isn't one you can put a vac nipple on the intercooler pipe going from turbo to intercooler closer to turbo the better. A manual boost controller you tee off the line you run from side of wastegate to turbo vac fitting. The port on top of wastegate is usually for electronic boost controller.
Old Apr 20, 2008 | 02:30 PM
Schister66's Avatar
Man U FTW
tundra2000
Oct 20, 2010 04:54 PM
2ndchirp
May 20, 2009 08:12 PM
almostjdmeg
Mar 10, 2008 01:00 PM
Lil_Jon
Apr 7, 2007 07:32 AM
Evil EG
Apr 8, 2002 12:54 AM
