turbo type r down under
Old Aug 13, 2006 | 12:59 AM
nz_turbo_type_r's Avatar
Default turbo type r down under
y0 whats up honda tech folks, i live in new zealand and im nearing the completion of the build of my turbo charged JDM 97 type r integra, came on here to find info bout what map sensors work with power fc's cause no one in new zealand seems to know. ive got a 2.5bar GM map sensor, anyone know if it'll run with it? otherwise i'll have a look around and see if i can find some info for myself. cheers for any help, heres a link to nzhondas.com to check out my car: http://nzhondas.com/phpBB2/4-v...rt=75
hope ya like it
Old Aug 13, 2006 | 01:22 AM
Taurine's Avatar
Default Re: turbo type r down under (nz_turbo_type_r)
nzhondas don't allow international access, well only at certain times of the night i think.
Upload your pics to imageshack or the like..
Old Aug 13, 2006 | 02:12 AM
americ_ian's Avatar
Default Re: turbo type r down under (Taurine)
here u go juddy
Old Aug 13, 2006 | 03:52 AM
awdgsx96's Avatar
Default Re: turbo type r down under (americ_ian)
Love the clean wingless look.
Old Aug 13, 2006 | 04:42 AM
nickromeo's Avatar
Default Re: turbo type r down under (awdgsx96)
that car IS SIcK! so is that manifold!
Old Aug 13, 2006 | 08:25 AM
AbitAvenger's Avatar
i like
Old Aug 13, 2006 | 10:21 AM
b00st-l0gic's Avatar
is your power fc already set up for boost? if so you can use a gm 3 bar sensor.
Old Aug 13, 2006 | 10:24 AM
BoostedEG6's Avatar
Default Re: turbo type r down under (b00st-l0gic)
Apex makes a map that will work with your Power FC. I know this because I have the Power FC also. here are some pics of it:
here is the wire harness that runs from the map sensor to the PFC
Old Aug 13, 2006 | 11:51 AM
TH33G4MON3's Avatar
Default Re: turbo type r down under (BoostedEG6)
Really nice looking car, looks like it makes real power too.
Old Aug 13, 2006 | 12:34 PM
non-VTEC's Avatar
who makes that manifold? looks nice......
Old Aug 13, 2006 | 11:14 PM
oh cheers for that ian, top man. the manifold was custom made, one of a kind
oh about that map sensor, is that wiring harness for the map sensor to power fc available from an apexi dealer? and the map sensor straight from a gm dealer? that 3bar one looks a bit different to my 2.5bar one. my one has no plug, im just supposed to solder the factory wiring to the points on it. maybe i should just go for the 3bar one, cheers heaps for ya help
Old Aug 14, 2006 | 04:28 PM
americ_ian's Avatar
haha
hey judd il grab that gm 2.5bar mpa sensor off ya
Old Aug 14, 2006 | 05:29 PM
Type-ARR's Avatar
Nice R.
Old Aug 14, 2006 | 06:48 PM
chargedek's Avatar
Default Re: turbo type r down under (Type-ARR)
Good work Judd,the manifold is awesome for actionDAN
Old Aug 14, 2006 | 09:15 PM
2LiterTurboSeR's Avatar
Default Re: turbo type r down under (chargedek)
Man that manifold is sick. How much did it run you to have made if you don't mind me asking? Equal length I assume?
Old Aug 14, 2006 | 09:56 PM
with any luck yeah it will make good power, rsl (ronnie lim) built engine should be good up to 18psi, yeah manifold runners are all equal length, about 15 90degree mandrel bends used in creating it, and it cost me NZD$550, but i supplied all the stainless. the guy who made it is pretty renowned in these parts for his custom manifolds, such tricky buggers to fabricate alot of people steer clearing of making custom manifolds.
yeah ian you can have that 2.5bar map sensor
Old Dec 16, 2007 | 11:40 PM
well hey i was floating around and dug up my old build thread, forgot i even had one on here.
bit of an update, car fully tuned made 279kw atw.
anyway after having it making crazy power for the street i decided that was enough of that and the car has since had its calling to become a circuit car, full chromolly 6-point roll cage, race seats and harnesses now compliment the stereo-less interior, its much more fun this way
Mikey3000
Jun 6, 2008 11:48 AM
turbohf
Jan 31, 2007 08:10 PM
Forced Teg
Apr 26, 2005 02:31 PM
SiRkid
Feb 17, 2002 03:52 PM
