Turbo Timing? What do i do?
Old Jun 21, 2003 | 06:53 AM
devonic's Avatar
Default Turbo Timing? What do i do?
well my turbos in, but im getting a little noise from the valves is sounds like, what should i retard the timing to? im using just the greddy turbo kit for 92-95 civic on my 97 civic coupe(y7y8hybrid), its got the stock wastegate so its only boosting 5psi? the manual said, what do i set the timing back too?
thanks
Old Jun 21, 2003 | 07:02 AM
Racerage1's Avatar
Default Re: Turbo Timing? What do i do? (devonic)
u sure its your valves? are u talking about ignition timing? stock timing should be fine for stock boost. maybe its your injectors that you're hearing.
Old Jun 21, 2003 | 07:52 AM
devonic's Avatar
racer - yea me and my friend turned my timing back a little bit last night(it was advanced a hair before turbo). when i got up over 3k rpm it started making a little noise from the engine
so i should just leave it at stock timing then since im going with the stock boost(for now) on the greddy turbo? if so i'll go rent a timing gun today
Modified by devonic at 6:07 PM 6/21/2003
Old Jun 21, 2003 | 08:53 AM
LshatchTurbo's Avatar
New User
Default Re: (devonic)
What your setup?
Old Jun 21, 2003 | 09:08 AM
devonic's Avatar
97 civic coupe
97 d16y7 block
98 ex intake manifold/head
stock exhaust
Old Jun 21, 2003 | 09:14 AM
Racerage1's Avatar
can u decribe the sound a little more? ticking? rattling BB's? etc.
Old Jun 21, 2003 | 09:18 AM
devonic's Avatar
well we set the timing back some, rattling bb's thats probly the closest thing i can think it sounded like, marbles in a pipe
Old Jun 21, 2003 | 09:24 AM
Racerage1's Avatar
u have the blue box hooked up correctly? u shouldnt be having any kind of detonation if you're at stock boost with the blue box. check everything again.
Old Jun 21, 2003 | 09:29 AM
devonic's Avatar
yea i followed this diagram
http://www.turbocivic.net/files/96-98bluebox.gif
and everythings wired up correctly, blue box is blinking its green light
i think it be that we just put the timing back way too far
i just went to pep boys and grabbed a timing gun, gonna try and set it to stock and see how it is
also, the other day in preparation for this i filled up with 92 octane with a little bit of 87 still in there, could that just be the 87 burning out?
Modified by devonic at 6:56 PM 6/21/2003
mausolf19
Sep 18, 2009 07:16 AM
team 15
Jun 16, 2007 02:00 PM
Dramier
Nov 10, 2003 11:02 AM
B_1_8_hatch
Oct 18, 2003 07:29 AM
