Turbo timer not always working?
Old Apr 16, 2002 | 11:58 PM
Shaun K's Avatar
Default Turbo timer not always working?
Just installed a Greddy turbo timer, and it doesnt always seem to work. You have to be really quick about turning the car off or it will just die. There seems to be a split second between turning the the key off and the timer taking over, and if you aren't quick enough that split second is enough for the engine to shut off. Anyone else had this problem, and is there a fix for it?
Old Apr 17, 2002 | 12:08 AM
GSRrR's Avatar
Default Re: Turbo timer not always working? (Shaun K)
Did you solder the wires? If you did not, check your wiring. Something might be loose.
Old Apr 17, 2002 | 09:24 AM
Shaun K's Avatar
Default Re: Turbo timer not always working? (GSRrR)
No, I used scotch-locks. It works sometimes, I just have to be really quick about turning the key. The car dies but the timer keeps counting down like the car is still running.
Old Apr 17, 2002 | 09:33 AM
adam's Avatar
sounds like wiring, maybe a defective unit. mine works fine
Old Apr 17, 2002 | 11:21 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Default Re: Turbo timer not always working? (adam)
Mine works fine also. You might want to re-check how you wired it up. I disabled the parking brake option and it ain't wired up.
Old Apr 17, 2002 | 02:21 PM
Shaun K's Avatar
Default Re: Turbo timer not always working? (DB8GSR)
Well, i wired it as per instructions, but after talking to Toshi at Greddy he gave me a couple other wiring options to try. He says things might vary a bit on a Honda/Acura vs. other cars. We'll see tonight. Thanks
Old Apr 17, 2002 | 07:21 PM
acuraintegraman's Avatar
is your foot completely off the clutch before you take the key out? I had a problem where i would shift the car into neutral, then taking the key out with my foot slightly on the clutch and the tt would shut off during my first week with the tt.
Old Apr 17, 2002 | 07:53 PM
Shaun K's Avatar
Default Re: Turbo timer not always working? (acuraintegraman)
yep, foot is off the clutch.
egmatt93
Sep 22, 2007 06:51 AM
Redz_EX
May 12, 2007 11:36 AM
phiberoptik
Nov 6, 2005 06:26 PM
redzcstandardhatch
May 7, 2005 11:12 AM
GruvyTune
Oct 29, 2001 01:20 PM
