turbo teg overboosting ????
Old Sep 30, 2012 | 05:18 PM
bbrian's Avatar
Post turbo teg overboosting ???? pics inside
i just recently had my car tuned made lil under 500 whp and held boost fine , out of know where my car starts getting boost creep like crazy , i put a 7lb spring in wastegate and it still boost all the way to 20 lbs , i have vacuum source off turbo directly to side port of wastegate , i have a jdl auto design ramhorn , with tial mvs 38mm wastegate , any ideas why it is doing that ?? it would hold boost fine before
Old Sep 30, 2012 | 05:23 PM
B and B's Avatar
Loved
Community Favorite
Default Re: turbo teg overboosting ????
(type of) boost controller? How much boost have u been running? And what else did u change so far? The Yogis will need more of the story, man.
Old Sep 30, 2012 | 05:35 PM
bbrian's Avatar
i have a hondata solenoid , but i completely unhooked it to narrow down problem , had a 13lb spring in before and was still boosting to 20 lbs , now i have a 7lb spring in it , but my car never use to do this out of knowwhere it started overboosting like crazy
Old Sep 30, 2012 | 05:50 PM
bbrian's Avatar
oh yea and when i do a pull with 7 lb spring in it will hold 7lbs for a second then at like 7 grand it boost up to 20 lbs
Old Sep 30, 2012 | 06:42 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
the problem occurred when you changed the spring out. i imagine your tune was based off the spring that was in it.
not sure if your tuned on s300, neptune, AEM or some fuel management system. but when you change the spring rate the boost solenoid percentage would need to be adjusted as well.
Old Oct 1, 2012 | 12:20 PM
bbrian's Avatar
No solenoid / boost controller is hooked up l
Old Oct 1, 2012 | 12:35 PM
bbrian's Avatar
car is on s300 on spring pressure no solenoid is hooked up , i unhooked it to find my problem of course its still doing it ,,,, bump
Old Oct 2, 2012 | 01:54 AM
fcluddington's Avatar
Sounds like you have the turbo going to the top port on the WG instead of to the bottom port which would give you spring psi. Try taking WG off and making sure it moves also, 7psi is not to hard to press in on.
Old Oct 2, 2012 | 06:00 PM
bbrian's Avatar
i have my boost source from turbo to side port of wastegate !!!!im thinking one of my pushlok fittings is leaking somewhere maybe
Old Oct 3, 2012 | 01:20 PM
bbrian's Avatar
bump
Old Oct 3, 2012 | 02:53 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you actually check anything as suggested? We can only do 20% of the work from behind the computer screen. Your lazy butf has to do the other 80%...
Old Oct 3, 2012 | 06:12 PM
bbrian's Avatar
nothing was suggested execept ppl asking if i had a boost controller , which i stated yes but isnt hooked up to narrow one thing down ???? what else was suggested ??
Old Oct 3, 2012 | 06:15 PM
bbrian's Avatar
the problem didnt occur when i chnaged springs out because it was doing it with the spring i had in it before , this happened out of knowhere , that was the reason why i chnaged springs to see if it would help
Old Oct 3, 2012 | 06:37 PM
DO IT ON ALL FOURS
Obviously you didn't read the help too well... The system was working, now it isn't. Electronic components removed to eliminate that side of things. Wastegate System was checked for leaks and is plumbed correctly... what does that leave other than some sort of mechanical failure or user/installer error. Pull the wastegate off and perform the suggested checks. They aren't as complicated as you are making them out to be.
Old Oct 4, 2012 | 04:47 AM
jubbeng's Avatar
disconnect the bottom hose and put shop air to it and see if the wastegate is opening
Old Oct 4, 2012 | 06:35 PM
bbrian's Avatar
took the wastegate apart , didnt see any defects or anything out of ordinary , reinstalled and still creeps like crazy ...bump
Old Oct 4, 2012 | 07:51 PM
Muckman's Avatar
Moderator in Chief
You need to make sure the two unused lower air ports are plugged.
Old Oct 4, 2012 | 08:37 PM
DO IT ON ALL FOURS
You can clearly see from the picture they are plugged Muckman...
OP - Just out of curiosity, where are you getting your boost readings from and what type of equipment are you using to get them?
Old Oct 4, 2012 | 09:24 PM
Muckman's Avatar
Moderator in Chief
Theres 3 air ports. His pictures only show 2 ports. His symptoms act like the wastegate is not seeing the boost reference. Either its leaking out the port or the hose. Try a different hose.
Old Oct 4, 2012 | 11:09 PM
rudebwoy's Avatar
sounds like you have a vacuum leak, close those extra bottom ports and see what happen
Old Oct 5, 2012 | 02:40 AM
SiRCiviC94's Avatar
Interesting
Old Oct 5, 2012 | 12:58 PM
bbrian's Avatar
all 3 ports are capped off , the other ports are for the watercooled stuff which isnt needed ,
i have the one vaccum source on the side directly to my turbo , i have a autometer boost gauge and recorded some datalog passes and u can clearly feel the extra boost when it hits about 7500 ,, bump oh yea and omni power 4 bar map sensor
Old Oct 5, 2012 | 01:04 PM
bbrian's Avatar
i just noticed on my car one of my top ports is plugged off , shoukld both be removed and open to run spring pressure ??
Old Oct 5, 2012 | 04:17 PM
DO IT ON ALL FOURS
The one is capped off because you are using a boost controller. I would be more concerned that the push-lock fitting possibly melted. Completely remove anything that may be installed in the top 2 ports. Better yet, when you remove the push-lock fitting try to blow through it.
Old Oct 5, 2012 | 04:52 PM
TheShodan's Avatar
Moderator
OR its not a 7psi spring as he believes.
