turbo techies please look!
Old Sep 3, 2004 | 11:55 AM
integracivic94's Avatar
Default turbo techies please look!
just recently boosted my d16z6 using a t25 and something is not right! i've got the boost guage and the blow off valve hooked up to the fpr and im reading 0.3 bar when i try to up the boost its feels faster but reads lower on my boost guage!! i also think that the blow off valve isnt working because the whoosh noise is coming from the air filter! think the blow off valve is leaking air aswell although the rubber is not split at all! it is not adjustable and it is only a low pressure spring! any ideas is greatlt appreciated!!!
Old Sep 3, 2004 | 01:31 PM
Redline94LS's Avatar
Default Re: turbo techies please look! (integracivic94)
first off, who is the manufacturer of your boost gauge? that could quickly answer your question.
second, what blow-off valve have you hooked up?
Old Sep 3, 2004 | 04:03 PM
B18 CYA's Avatar
whoosh coming from air filter? ouch...could be compressor surge
Old Sep 5, 2004 | 06:42 AM
Default Re: (c2nap)
not sure on the make of the guage or the blow off valve! could it be that the fpr is sucking the bov open or something? getting a lil worried bout it! thanks for the replys
Old Sep 5, 2004 | 07:18 AM
EM1 MIKE's Avatar
Default Re: (integracivic94)
Theres no manufacturer name anywhere on the boost gauge?
Are you using a 1st gen DSM blow off valve?
Old Sep 5, 2004 | 07:26 AM
CRX T-Si's Avatar
Default Re: (EM1 MIKE)
Details will help on this.
List what exactly what you got.
Some BOV don't make much nosie so you have to put your hand infront of the BOV to see if air is coming out.
If you say that you boost it higher and the boost guage does not read the higher readings then it sounds like a leak in the I/C pipe somewhere.
You might have a loose connection so the turbo might be spooling more but the air is leaking out somewhere.
Old Sep 5, 2004 | 09:02 AM
Default Re: (CRX T-Si)
right i found out that the boost guage is racetech! a british make. got it used of a buddy so it should be ok! how would i check for boost leakage? i checked all my joins and hose clips etc. thanks for the input really appreciate it
Old Sep 5, 2004 | 09:34 AM
anyone?
Old Sep 5, 2004 | 10:18 AM
CRX T-Si's Avatar
The way to check the I/C pipe to see if it's not leaking is just move the the pipes around a bit. If it's loose then you will feel it if you don't see it first.
Dmc1
Jan 26, 2006 11:39 AM
98_4drCivic
Sep 6, 2005 09:10 PM
Sinner
Sep 24, 2004 05:15 PM
ATS*Mark
Mar 2, 2004 06:43 AM
