Suggested turbo?
Old Nov 25, 2013 | 08:16 AM
usdmgsrteggy's Avatar
Default Suggested turbo?
I just bought a 2000 Acura Integra GSR with the 1.8. I am thinking about putting a turbo on it but i have no idea what turbo i should get for it. I was hoping for suggestions on who's turbo and which turbo. My car is stock minus the skunk 2 coil-overs and sway bars in front and rear.
Old Nov 25, 2013 | 09:22 AM
cvelazquez's Avatar
Default Re: Suggested turbo?
the engine is going to remain stock?
Old Nov 25, 2013 | 11:27 AM
besides for new injectors, fuel pump, and being tuned yeah it would be
unless other stuff is NEEDED, but its my DD too so i was thinking about a 8-10 psi boost depending on the turbo
Old Nov 25, 2013 | 12:09 PM
Schister66's Avatar
Man U FTW
**Moved to Forced Induction**
Step 1: Read the Forced Induction FAQ
Steps 2-28: See above
Stock B series is good for ~3-350whp in stock form.
PSI means nothing...set a POWER goal, not a boost goal as it differs from turbo to turbo/setup to setup
Old Nov 26, 2013 | 04:27 PM
brs256's Avatar
I wouldn't go any bigger than a t3/t4
you need to factor in the cost of getting it tuned, and the cost of a programmable ecu
you also need to be able to stop faster before you need to be able to go faster
Old Nov 26, 2013 | 05:01 PM
TheShodan's Avatar
Moderator
boy, that narrows it down..
Old Nov 27, 2013 | 05:14 AM
Schister66's Avatar
Man U FTW
Narrowed it down from 50,000 choices to 49,998
Old Nov 27, 2013 | 05:31 AM
Turbo-LS's Avatar
50 trim would do well with a .63 housing. Will spool nicely and mae the power a stock GSR can handle and be a fun car to drive. PLus 50 trims are on the cheaper end. Buy a garrett unit.
Old Nov 27, 2013 | 05:55 AM
Freemananana's Avatar
Truth. While I have a .57 trim from Garrett, it is a nice turbo. They can be had cheap. Like say, someone blew up their new build and part out their turbo kit. Got mine for under $400 and it was pretty much new. Still had all the marking from Greg on it.
ggangtong81
May 28, 2007 12:55 PM
iguano
Apr 17, 2006 07:39 PM
XES
Oct 19, 2005 05:50 PM
jaM3s Bond
11
Aug 6, 2003 11:39 AM
00ITR725
Mar 27, 2003 08:30 PM
