Turbo spitting oil
Old May 25, 2010 | 06:34 PM
b15ser's Avatar
Default Turbo spitting oil
hi i need help i have a problem.... my car boost fine no shaft play holds boost and everything its just after i slam it hard there is oil around the inside of the turbo and on the lip idk how this can happen or y its happening any help?
Old May 26, 2010 | 09:19 AM
boosted.si04's Avatar
Default Re: Turbo spitting oil
Well first u should really have a filter on ur turbo. Check all ur feeds and make sure they all are on there tight. Second the oil around ur turbo my first turbo from eBay did that mean ur turbo leaking and is going bad so I would go get it rebuilt stop smashing on it before it blows lol but yeah if it's a good turbo get it rebuilt why u always buy new because they have warrentys on the turbos.
Old May 28, 2010 | 03:07 PM
b15ser's Avatar
thanks but idk wats up with it the turbo seemd to be good it only happens when i hit boost under normal driving its fine and its an ebay turbo but its completely fine like i said no shaft play spins freely im ??????
Old May 28, 2010 | 04:04 PM
siblues's Avatar
I totally disagree it makes no sense to have it rebuilt before figuring out the problem and if it has no shaft play whatsoever it may not need a rebuild.Check the return line to make sure it isnt having issues returning the oil to the pan and what is the oil pressure you are getting on the feed line?
Old May 28, 2010 | 11:41 PM
Slow_boost's Avatar
Someone knowledgeable has free reign to correct me but your turbo might not have shaft play and still have blown seals which would lead to the oil buildup on your comp housing(Im assuming from your less than descriptive OP).
Throw the ebay turbo in the trash and get something thats worth running.
On a side note: SiBlues, why dont you like Jdogg?
Old May 29, 2010 | 03:17 AM
siblues's Avatar
He scammed me I will pm you the details.
The seals could be bad also and I didnt know it was an ebay turbo they are known to fail very easily also.
mike333
Sep 25, 2010 07:57 AM
GEN2 LS
Jul 3, 2008 04:59 AM
crazzeboost
Jul 20, 2005 07:09 AM
JV
Jan 23, 2002 01:23 PM
