Turbo sizing
Old Sep 16, 2002 | 12:16 PM
2.2's Avatar
2.2
Default Turbo sizing
I am going to be swapping a B16 into my hatch and want to turbo it. I am looking only for 7 - 8psi and nothing more since this will be my daily driver.
Is a T3 big enough to support this? I see everyone uses T3/T4's and the like, and was wondering if these are used for future plans.
Kenton
Old Sep 16, 2002 | 02:08 PM
2.2's Avatar
2.2
Default Re: Turbo sizing (2.2)
Anyone?
Old Sep 16, 2002 | 02:13 PM
The_Head's Avatar
I'm going with a T3/T4 .50 A/R compressor. From the compressor map plotting I have done, it should do pretty good at 7 psi.
Old Sep 16, 2002 | 02:23 PM
2.2's Avatar
2.2
Default Re: Turbo sizing (xThexHeadx)
Are you taking into consideration turning up the boost in the future? I am looking for the smallest turbo to give me a good and steady 7psi all the way to redline. I dont ever want to go above 10.
Also, what do the A/R numbers mean and how do they affect the turbo's personality?
Kenton
*EDIT* - Typo
[Modified by 2.2, 3:24 PM 9/16/2002]
Old Sep 16, 2002 | 03:11 PM
Doogie Howser's Avatar
i was thinking if i went with a b16 to get a sohc kit, and buy a hks manifold, with the 15g turbo it would be perfect for 7-8 psi because the fast spool would make up for the torquless 1.6.....although i think the 15g could loose steam reving up high
Old Sep 16, 2002 | 03:14 PM
ArizonaTurbo's Avatar
If you just want a quick spooling turbo to produce 250-275 hp, then stick with a T3. Here are the specs to a T3 that will be perfect for you:
.48 A/R Turbine Housing
Stage I Turbine
.60 A/R Compressor Housing
Super 60 Compressor Wheel
Old Sep 16, 2002 | 04:50 PM
2.2's Avatar
2.2
Default Re: Turbo sizing (TurbochargedSER)
Sweet, thanks for the reply.
Old Sep 16, 2002 | 05:00 PM
integra-modder's Avatar
The amount of boost you have is controlled by your BOV and wastegate. as soon as the turbo spools up itll spool something around 30 psi if there is no valve to release the pressure
Old Sep 16, 2002 | 05:27 PM
2.2's Avatar
2.2
Default Re: Turbo sizing (integra-modder)
If the turbo is too small it wont be able to provide the airflow to support the boost.
Old Sep 17, 2002 | 12:30 PM
almost all T3's that will bolt onto a honda are capable of it
Old Sep 17, 2002 | 01:53 PM
2.2's Avatar
2.2
But will they keep in their efficiency(sp?) range? A lot of times no.
usdm ws6
May 30, 2006 04:24 PM
93first1
Apr 5, 2006 05:12 AM
B16Civic93
May 7, 2005 01:30 PM
justBLZE
Jul 27, 2003 08:08 PM
1tyme
Oct 20, 2002 03:18 AM
