turbo sizing
Old Aug 7, 2006 | 05:49 PM
del-sol-95's Avatar
Default turbo sizing
i have a garrett turbo and have no idea what the trim is ,can anyone explain to me how to size the trim
Old Aug 7, 2006 | 07:41 PM
TheShodan's Avatar
Moderator
Default Re: turbo sizing (del-sol-95)
Wheel trim topic coverage
Trim is a common term used when talking about or describing turbochargers. For example, you may hear someone say "I have a GT2871R ' 56 Trim ' turbocharger. What is 'Trim?' Trim is a term to express the relationship between the inducer* and exducer* of both turbine and compressor wheels. More accurately, it is an area ratio.
* The inducer diameter is defined as the diameter where the air enters the wheel, whereas the exducer diameter is defined as the diameter where the air exits the wheel.
Based on aerodynamics and air entry paths, the inducer for a compressor wheel is the smaller diameter. For turbine wheels, the inducer it is the larger diameter
GT2871R turbocharger (part # 743347-1) has a compressor wheel with an exducer diameter of 71.0mm and a trim of 48. What is the inducer diameter of the compressor wheel?
Exducer diameter = 71.0mm
Trim = 48
The trim of a wheel, whether compressor or turbine, affects performance by shifting the airflow capacity. All other factors held constant, a higher trim wheel will flow more than a smaller trim wheel.
However, it is important to note that very often all other factors are not held constant. So just because a wheel is a larger trim does not necessarily mean that it will flow more.
Old Aug 8, 2006 | 12:54 AM
pane93civhb's Avatar
how will a .48ar exhaust / .60 compressor flow oppose to a .63ar exhaust and .60compressor. Im worried that my turbo with the .48ar exhaust will not put out enough power for me.. Im trying to reach 350whp.. give me yur thoughts.
motoxxxman
Jun 9, 2017 06:25 PM
turbo-crx
Jan 26, 2009 04:09 AM
twkdCD595
Aug 3, 2007 09:19 AM
thizboii
Feb 11, 2007 08:34 PM
scartail
Dec 19, 2004 04:54 AM
