Turbo setup question with picture
Old May 28, 2008 | 08:37 PM
accord99power's Avatar
Default Turbo setup question with picture
After hours of research i came up with this drawing to hookup the vacuum hoses this weekend, please let me know if i need to make any changes thankyou.
Old May 28, 2008 | 09:43 PM
hondamn1320's Avatar
Default Re: Turbo setup question with picture (accord99power)
the boost gauge and bov should be hooked up to a vacuum source post throttle body, or to a vacuum manifold of some sort.
the box "T" that comes with the boost controller should go inline between the hose on the compressor housing and the bottom port of the wastegate. the top port should not be connected to anything, unless you are using an electric controller.
Modified by hondamn1320 at 10:48 PM 5/28/2008
Old May 29, 2008 | 04:55 AM
Default Re: Turbo setup question with picture (hondamn1320)
ahhh thanks for the info, where does the 2nd line on the mbc connect to then?
Old May 29, 2008 | 05:45 AM
that's the bleeder. leave it open to the atmosphere.
Lao17
Apr 2, 2011 05:28 PM
turbo sol
Mar 1, 2009 08:47 AM
Funanin
10
Jan 13, 2008 07:37 AM
draconx
Mar 15, 2006 06:03 AM
jdm-ray
May 15, 2005 09:37 PM
