turbo setup question
Old Feb 22, 2009 | 02:11 AM
keving85's Avatar
Default turbo setup question
ok i have everything on the car.... except downpipe i still have to weld in a spot for the o2 sensor... but this came with the kit and it looks like it goes on the map sensor.... my question is do i need it at all..?
the car is not tuned but will be tuned on crome
Old Feb 22, 2009 | 06:10 AM
bigD's Avatar
Default Re: turbo setup question
looks like a missing link you dont need it with crome, only time you would use that is with a fmu.
Old Feb 22, 2009 | 10:07 AM
keving85's Avatar
ok i am going to drive about 200-500 miles to break the motor in... new rebuild and new clutch. before i go get it tuned on a dyno. so my question now is should i run that thing that goes on the map sensor til i get it tuned.....
my plan is to keep it out of boost til i get it tuned and til i break the motor in.
kev
Old Feb 22, 2009 | 10:29 AM
boostedeg302's Avatar
no you dont need to run it at all. The stock map sensor will by fine without the missing link until the tune. If you plan to run more than 12psi then i would get a larger map sensor instead of running the missing link
Old Feb 22, 2009 | 11:08 AM
keving85's Avatar
thanks for yall's help... i only plan to run 7-10 psi... depending on how the tune goes.. right now it is setup for 7psi
Old Feb 22, 2009 | 12:48 PM
bigD's Avatar
kev
Still on stock injectors? Do you have a chipped ecu with a basemap? The stock map can only read boost with a chipped ecu, if the stock ecu reads boost from the map it will go into safe mode. I would aslo keep it under 10 psi on the stock map.
Old Feb 22, 2009 | 01:56 PM
Ls_dx's Avatar
I would keep it under ZERO psi, with the stock map and Injectors. . .
Jthw
Engine Management and Tuning
Oct 30, 2016 12:07 PM
shaggyeg6si
Jul 12, 2008 03:00 PM
jrs2ksi
Oct 22, 2006 02:48 PM
94_CRVtec
May 17, 2005 09:28 PM
Greg456
Feb 7, 2004 06:25 PM
