map sensor question
Old Feb 7, 2004 | 10:06 AM
Greg456's Avatar
Default map sensor question
Im planning on running mild boost in my b18c5 up to 12psi. Do I need to change the map sensor or can i just buy the missing link?
Old Feb 7, 2004 | 10:24 AM
twkdCD595's Avatar
Default Re: map sensor question (Greg456)
what do you plan to use for fuel management?
Old Feb 7, 2004 | 10:25 AM
boostsohfast's Avatar
You can use the missing link with a fmu. I don't think 12 psi can be considered mild boost on a b18c5 though. Are you running stock compression?
Old Feb 7, 2004 | 10:48 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greg456 &raquo;</TD></TR><TR><TD CLASS="quote">Im planning on running mild boost in my b18c5 up to 12psi. Do I need to change the map sensor or can i just buy the missing link?</TD></TR></TABLE>
Ka-boom!
Uh, hold off on boosting and lurk the forum for a couple weeks. Pay special attention to, and use the search function for, threads concerning engine management, and how exact you have to be tuning a high CR turbo setup.
You've basically asked a question that tells me you lack information I could type for a couple hours and not fully impart to you. Be patient, give yourself the time to do the research you need to do, ask a few Q's here and there for help, and you'll have a nice ride. The alternative is shitting a very expensive C5.
Old Feb 7, 2004 | 03:09 PM
Greg456's Avatar
Im using a hondata s200 with 550cc injectors and apexi boost controller. Stock internals, and a maxrev turbo kit. Im gonna run between 8psi and 12psi, depending on what fuel im using.
Old Feb 7, 2004 | 04:05 PM
turbo96wr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greg456 &raquo;</TD></TR><TR><TD CLASS="quote">Im using a hondata s200 with 550cc injectors and apexi boost controller. Stock internals, and a maxrev turbo kit. Im gonna run between 8psi and 12psi, depending on what fuel im using.</TD></TR></TABLE>
use a high flow intank pump and yes run a 3-bar map (get rid of FMU)
Old Feb 7, 2004 | 04:14 PM
grndcont's Avatar
ya, dont do **** until you've done alot of resurch. ask alot of questions to the right people, and you'll be ok. my 2c= 10psi or &lt; on stock internal c5's.
Old Feb 7, 2004 | 06:25 PM
Default Re: (grndcont)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grndcont &raquo;</TD></TR><TR><TD CLASS="quote">ya, dont do **** until you've done alot of resurch. </TD></TR></TABLE>
You're asking about missing links and how much your stock MAP sensor can read, it's a good sign you're not sure of what is going on and what you need. Do the research, or find a reputable place to assist you and help with your tuning.
chrisfromsrq
Sep 26, 2009 12:20 AM
HONDA300
10
Sep 20, 2007 07:41 PM
l2yanE
Oct 2, 2005 10:15 AM
CarpAngler
Feb 4, 2005 05:30 AM
BolivianFuego
Nov 10, 2003 12:20 PM
