Turbo setup complete
Old Feb 9, 2004 | 04:43 PM
whiteblurr's Avatar
Default Turbo setup complete
Fired her up today.... WOOT!
Here's some pics. Enjoy
Here's a tech question in hopes of my thread not getting locked
Should I go ahead and completely remove the center section of the bumper for the intercooler? There's about 3/4 of an inch of intercooler core that is being covered by the very bottom portion.......
Old Feb 9, 2004 | 05:31 PM
onetwothree's Avatar
Default Re: Turbo setup complete (whiteblurr)
Which turbo is that? And please don't say t3/t4. I hate when I go to the street races and ask someone what turbo they have they say "t3/t4" Do you have any more pics of the car?
Old Feb 9, 2004 | 05:40 PM
Turboteggy's Avatar
Default Re: Turbo setup complete (onetwothree)
Leave the bumper as is. That little bit of plastic won't make any real difference, plus the more stock it looks, the less 'bad' attention you will receive.
Goood job
Old Feb 9, 2004 | 05:46 PM
quikB18B's Avatar
Default Re: Turbo setup complete (Turboteggy)
I spy a Revhard Intake manifold
Looks nice, looks like quite a bit of weight reduction under the hood
Old Feb 9, 2004 | 06:00 PM
whiteblurr's Avatar
The turbo is a Precision SC50.
Ok, so the bumper stays "as is" Although I still need to cut a few places on the corners for the IC pipes to clear a little better.
Thanks guys
Old Feb 9, 2004 | 06:06 PM
More pics of the car. Any internals?
Old Feb 9, 2004 | 06:52 PM
whiteblurr's Avatar
JE pistons, Crower rods. 10.5 compression
Old Feb 9, 2004 | 06:57 PM
x2gold's Avatar
whiteblur, i'm building one just like it, a few questions that you could hopefully help me out with. Is that the stock bumper (how much had to be modified to make it fit). Also, as a side note, how did u hook up the fuel pressure guage to the filter. Thanks.
sporkcrx's Avatar
hot!
Old Feb 9, 2004 | 06:58 PM
JrCRXHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteblurr &raquo;</TD></TR><TR><TD CLASS="quote">JE pistons, Crower rods. 10.5 compression</TD></TR></TABLE>
i really like that setup for the street how well does it work can you feel the difference between that and like 9:1
Old Feb 9, 2004 | 07:06 PM
GReddy SI's Avatar
what intercooler is that?
Old Feb 9, 2004 | 07:32 PM
whiteblurr's Avatar
Default Re: Turbo setup complete (GReddy SI)
The bumper is a OEM replica... I put the OEM and the replica side by side and couldn't tell a bit of difference.
The IC is a Drag intercooler I bought from ImportParts.com.
Their is a fitting on top of the fuel filter in which the FP gauge screws into.
Old Feb 9, 2004 | 09:00 PM
VinceVTEC's Avatar
looks awesome!
Old Feb 9, 2004 | 09:10 PM
B18bEK's Avatar
now you just need to complete the paint
Old Feb 9, 2004 | 09:50 PM
TurboR1391's Avatar
Default Re: (B18bEK)
Man with 10:5:1 compression that thing must spool up like a jet. When I originally sent my engine to Golden Eagle to be built I was going with 10:6:1, but I called them back and punked out.
Old Feb 9, 2004 | 09:56 PM
Patrick's Avatar
Is the BOV knockin the fender?
Looks really nice though.
Old Feb 9, 2004 | 11:01 PM
Blackack26's Avatar
Default Re: Turbo setup complete (Patrick)
Could you describe how it rides? What do you think of the turbo?
Old Feb 9, 2004 | 11:43 PM
ringgold's Avatar
Default Re: Turbo setup complete (Blackack26)
I wanted to build a higher comp ratio turbo'd engine. I actually wanted to build a 10.5:1 engine. So how does that thing spool? is it running pretty smooth or what?
Old Feb 10, 2004 | 04:47 AM
whitelsteg's Avatar
Dam thats sick...bump for that
Old Feb 10, 2004 | 07:00 AM
whiteblurr's Avatar
Default Re: Turbo setup complete (ringgold)
I haven't drove it hard yet because it needs to be tuned first. I will have the car tuned on Friday hopefully. The response from the turbo should be quick enough for me
Old Feb 10, 2004 | 07:01 AM
whiteblurr's Avatar
Not the BOV itself just the vaccum nipple on the side of it. I'm going to make a bracket for it to pull it away about 1/4 inch from the frame.
Old Feb 10, 2004 | 07:06 AM
Archidictus's Avatar
Unceasing Measure
Looks hot as hell . Huge props for the high compression setup .
Old Feb 10, 2004 | 07:18 AM
chidoks's Avatar
Default Re: Turbo setup complete (Archidictus)
do u have sleeves??
Old Feb 10, 2004 | 08:10 AM
JrCRXHF's Avatar
Default Re: (TurboR1391)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboR1391 &raquo;</TD></TR><TR><TD CLASS="quote">Man with 10:5:1 compression that thing must spool up like a jet. When I originally sent my engine to Golden Eagle to be built I was going with 10:6:1, but I called them back and punked out. </TD></TR></TABLE>
i am running 10.5 or 10.2:1 what ever is stock in a b16 5mill block but i really like how quick the turbo comes up with with this comp. and u don't notice lag as much down low before the turbo comes on drives like a stock b16 but the down side is that you can not make quite as much power up top but i run my car down the road more then at the track and if i go to the track it is a auto X
just my 2 cents
Old Feb 10, 2004 | 09:42 AM
bo0sted's Avatar
Default Re: (JrCRXHF)
very nice
