Turbo Set Up
Old Mar 13, 2006 | 07:40 AM
tags95civicex's Avatar
Default Turbo Set Up
Hey ladies and gents, I just thought I would post up what I'm planning on for a turbo build, I've spent a lot of time reading stickies and I think I finally came up with a nice setup. So I thought I would post it up on a few sites to see what everyone thinks about it or if they have any suggestions.
The engine is a D16Z6 in a 95 EJ1
Internals
SRP 9.0:1 pistons .010+
TunerToys Rods
ACL bearings
SRP rings
Endyn Block Posts
Block decked to make sure it is true
Stock crank but may micropolish(not sure on this one yet)
Head
Stock Cam, springs, valves and retainers
Mild Port and Polish
2 stages colder NGK plugs
Valve Job
Head plained to make sure it is true
Turbo Kit
T3/T04B Garrett rebuilt turbocharger
-.47 trim Compressor Wheel
-.60 A/R Compressor Housing
-.48 A/R Turbine Housing
-Stage 2 Turbine Wheel
Short ram manifold
2.5 " exhaust downpipe into a flex then a flange, then straight to hi flow cat, back to axle another flange then into Megan Racing N1 muffler
JohnnyRaceCar 6"intercooler
2.5"intercooler piping
HKS blow off valve
Tial 38mm wastegate (8.7 psi spring)
Walbro Fuel Pump (255Lph High Pressure)
DSM 450cc injectors
Greddy Turbo Timer
Greddy Profec B
Ostrich Unit
Crome Pro
SVE 3-Bar MAP Sensor Kit
I most likely forgot something but that is what I have in mind so far, some parts are already bought. So if anyone has some suggestions just post them up. Thanks
Ps. I was looking around but can't seem to find a sticky that says when you're not a trial user anymore? I know its most likely right in front of my face but can some one point me to it.
Thanks
-TAG
Dr Drew
Jul 13, 2012 06:15 AM
d98clturbo
May 26, 2003 04:52 PM
DubyaAye
Apr 21, 2003 07:13 PM
DimSum321
Mar 14, 2003 12:20 AM
