Turbo safe for high miles?
Old Feb 23, 2008 | 11:45 PM
waz88's Avatar
Default Turbo safe for high miles?
Hello everyone, I have been wanting to do a turbo for a long time, but when I came to buy one, somone was telling me that I had to do a complete rebuild or a head package. This right there broke my dream. I know a rebuild cost soo much, or even a head package(about 1500-1900) because thats 75% of my savings I had for a turbo.
I have a 97 gsr with 145000miles (45k of which I put on the car). If I put a turbo to get aroun 220-250whp(most likly greddy), would it be fine or what do u think? <U>PLEASE </U>help me out with this. Compression values are all close (200 range), and car well maintaind with new t-belt/consistant oilchange(every2500mi) and tune up. Please dont ignore, as I have searched quite a bit(the red search button and on google) but with no success.
Thanx in advance
Old Feb 23, 2008 | 11:48 PM
FastEg6's Avatar
It'll be fine, I threw a turbo on my gsr with 180+k miles on it, ran like a champ. Made 315hp @ 12psi, but I wanted more out of it so I did a complete rebuild. Just get it tuned and and take care of it, do not half *** things and it should be fine.
Old Feb 24, 2008 | 03:42 PM
waz88's Avatar
Default Re: (FastEg6)
thanx for the reply
waz88's Avatar
Default Re: (waz88)
does anyone else have any opinion?
thank you
Old Feb 24, 2008 | 03:46 PM
slodel's Avatar
Default Re: (waz88)
i have a d16z6 turbo
the miles are around 220,000 plus some, odometer works sometimes
it will be fine just do what FastEg6 said
Old Feb 24, 2008 | 04:14 PM
perseverance's Avatar
while mileage does make a lot of difference..consider the other factors. any oil leaks? have u done a compression test on the motor? compression test will give u a good idea on what your motor will be able to handle but i'd still do some minor rebuilding if you're planning on dd with it. as they say tho...you gotta pay to play.
Old Feb 24, 2008 | 08:56 PM
Boosted_B_Series's Avatar
boost it, we boost stock engines all the time with a whole lot more miles than that. You will love it. I' piece together a kit and not go with a lil greddy kit.
Old Feb 24, 2008 | 09:26 PM
spoonef's Avatar
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">while mileage does make a lot of difference..consider the other factors. any oil leaks? have u done a compression test on the motor? compression test will give u a good idea on what your motor will be able to handle but i'd still do some minor rebuilding if you're planning on dd with it. as they say tho...you gotta pay to play.</TD></TR></TABLE>
180 160 175 180 people say im oka but im not sure
Old Feb 24, 2008 | 09:30 PM
I know when I dropped compression in number 3, bye bye ringlands.
Old Feb 24, 2008 | 09:36 PM
champLSinteg's Avatar
Default Re: (spoonef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonef &raquo;</TD></TR><TR><TD CLASS="quote">
180 160 175 180 people say im oka but im not sure</TD></TR></TABLE>
What motor? If it were my motor I would definately think about rebuilding or at least re-ringing it.
To the OP, with only 250hp max as your goal I see no problem with you turboing it as it stands.
Old Feb 24, 2008 | 11:15 PM
waz88's Avatar
Default Re: (champLSinteg)
thnx everyone for this info.
Now as for re-ringing it, what does that require? Is it a rebuild or something of that sort or is it a quicker process?
Old Feb 24, 2008 | 11:40 PM
Default Re: (waz88)
it depends on how your cylinder walls look. Most likely all you would need to do is a hone and a new set of rings. Since you're on a budget just do the hone yourself with a dingleberry hone. I've had good luck doing it myself. Search a diy on that.
Old Feb 26, 2008 | 11:25 AM
FastEg6's Avatar
I'd probably go for some new rings maybe. Other then that you should be okay. Whats your compression at??? If you maintain it well, keep an eye on things, check oil, check plugs, all the things you can think of you will def be ok. Make sure you get it tuned, I suggest you not boost it until you get everything you need to turbo your car. Get it tuned and you'll be good. I never had to change my rings with my completely stock internal gsr. I put 70000 miles on it when boosted, give or take a few. Never had any problems.
Old Feb 26, 2008 | 11:44 PM
waz88's Avatar
Alright, the compression test is done and these are the numbers:
145, 145, 145, 145.
For one of them, the comp went to 175, but after a minuite or so I did it again and it was 145. I did all of he 2 or 3 time and all are around 140-145... The gauge goes up right when the key i turned, which I heard is a good thing too.
Please advice and thanx all for ur help
waz
Old Feb 26, 2008 | 11:57 PM
HondaKyle's Avatar
Default Re: Turbo safe for high miles? (waz88)
just saw on S2ki an S2000 put down 503whp on a 100% stock motor no head gasket
Old Feb 27, 2008 | 10:25 AM
waz88's Avatar
Default Re: Turbo safe for high miles? (HondaKyle)
wow thats pretty intense
Old Feb 27, 2008 | 11:37 AM
slodel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">just saw on S2ki an S2000 put down 503whp on a 100% stock motor no head gasket </TD></TR></TABLE>
no head gasket???
xxtruoutlawzxx
Mar 14, 2004 03:17 PM
dtec
Aug 5, 2003 02:38 AM
VieTec
Mar 18, 2003 11:34 AM
psileepR
Nov 18, 2002 11:42 PM
skhonda
Sep 18, 2002 08:31 AM
