turbo options
Old Dec 30, 2009 | 07:27 PM
LS-turboner's Avatar
Default turbo options
for the money, whats the best affordable t3/t4 turbo you could get? im shootin for a reliable 300whp on a b18b1. 15-20 psi. (stock sleeves, forged pistons, eagle rods, a/m valvetrain. i want it to spool around 3500 rpms. any suggestions for a turbo/trim for this application?
Old Dec 31, 2009 | 08:04 AM
boostedEF91's Avatar
Default Re: turbo options
garrett 50trim will get you there. quick spool good for 300. not much more after that tho.just go with a 57trim. good for 400hp and not a lot of money. if you have a built motor why waste money on a small turbo. spend the cash and get something worth buying. that way you can make 300 and even 400. without changing things.
Old Dec 31, 2009 | 11:45 AM
cool, ya i definately want room for improvement, i dont want to max out the turbo i get, i want to be able to tune for more boost and power when the time is right...(P.I.R. track nights?!? lol). anyone else?
Old Dec 31, 2009 | 02:22 PM
CoreyR's Avatar
50 trim is the turbo you need.
Old Jan 1, 2010 | 03:26 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
your from oregon?
I have a ebay t3/to4e .63 exhaust .50 ar on my ls-t made 314whp pretty easy and spools about were you want yours too. but Im pretty sure it wouldn't make past 340-350ish. plenty of power for my little car though.
Old Jan 2, 2010 | 11:37 AM
hows it holding up? no burning oil, or bad seals or cracks? if so, i might try one out while i save for a big garrett or presicion... where you from? id like to check your set up. how much did that set you back?
Old Jan 2, 2010 | 11:50 AM
Turbo1.6's Avatar
As stated above, get a Garrett T3/TO4e, 50 or 57 trim.
Old Jan 2, 2010 | 01:39 PM
Loved
Community Favorite
holding up good so far. I had some setbacks because I bought a used motor that got a rod knock after 3 days of running it. no burning oil, you have to make sure you run a oil restrictor. and I can show you a link of the sell that I bought mine from, def feels alot better quality than my old ebay turbo I had on my sohc (when I bought it it already had shaft play... alot)
although a garrett is never a bad option it all depends on your budget.
Im into my whole kit around 650, with injectors and a 3 bar map.
and Im from salem.
Old Jan 2, 2010 | 11:27 PM
crvek9's Avatar
personaly id go sc61 or 6262 in that range sumwhere
Old Feb 4, 2010 | 09:42 AM
Hatorade's Avatar
and Im from salem.
hey would you mind pm me the name of the ebay seller for that as well?
thx!
95BlkGSR
May 19, 2009 04:47 PM
civickiller
Dec 4, 2008 06:18 AM
EJ8 GSR-T
Mar 28, 2006 04:09 AM
DC2 BoZz
Sep 25, 2004 07:44 PM
hondanacura4life
Aug 16, 2002 05:58 PM
