turbo oil feed and water feed?! garrett T25
i have a t25 turbo from a saab and it has two feeds and two returns one for water one for oil. however one feed is bigger than the other and attached using a banjo bolt fitting and the other is a different fitting but thinner tube?
i am wondering which is more likely to be the oil feed and which the water feed? i dont have much experience with turbos so any help would be great
thanks
thanks
Re: turbo oil feed and water feed?! garrett T25 (djnikko)
Dunno if T25's on Saab's are different, but on a Mitsubishi T25, the banjo fittings (2 identically sized) are for water. A smaller line with a AN type of fitting is the oil feed line, with the oil drain consisting of a flanged drain hole with 2 bolts attaching the drain line to the turbo housing. This may be completely different on a Saab though...
Re: turbo oil feed and water feed?! garrett T25 (fsp31)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 »</TD></TR><TR><TD CLASS="quote">Dunno if T25's on Saab's are different, but on a Mitsubishi T25, the banjo fittings (2 identically sized) are for water. A smaller line with a AN type of fitting is the oil feed line, with the oil drain consisting of a flanged drain hole with 2 bolts attaching the drain line to the turbo housing. This may be completely different on a Saab though...</TD></TR></TABLE>
can anyone verify this for me?
i have my turbo mounted to my manifold and the hole that has 2 bolts with a hole in the middle is facing straight down and would be perfect if it is the oil drain and not the feed........ please let me know!
Re: turbo oil feed and water feed?! garrett T25 (sloorex)
>>i have my turbo mounted to my manifold and the hole that has 2 bolts with a hole in the middle is facing straight down and would be perfect if it is the oil drain and not the feed........ please let me know!<<
That is MOST DEFINITELY the turbo drain. Seriously though, it is I promise. Do you have the bolts to go with it? Should be either 10 or 12 mm, can't remember which. The drain hole itself is about a half inch across.
Drain hole is about 1/2" accross, the coolant lines are threaded hole about 14mm wide. Look at it like this, find the smallest threaded hole out of the 4 holes, that one is the feed line, right directly on the opposite is the return/drain hole.
Then the two identical size holes on the 3 and 9 o'clock of the feed and drain are the coolant lines.
stan
stan
Re: turbo oil feed and water feed?! garrett T25 (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">Drain hole is about 1/2" accross, the coolant lines are threaded hole about 14mm wide. Look at it like this, find the smallest threaded hole out of the 4 holes, that one is the feed line, right directly on the opposite is the return/drain hole.
stan</TD></TR></TABLE>
thanx guys.......... and stan, i emailed you about a feed kit........
CivicDude2k4
09-05-2006 08:24 PM
Scott - 93HB Si
09-04-2002 04:14 AM
