TURBO newbie
i was thinkn' of getting a greddy trubo kit for my Rex Si, but had some ??'s
1. do i need to build up my engine before i install the kit?
2. can i jus run on the stock internals at 7psi of boost?
thanx in advance
smart comments welcome
thanx in advance
welcome to HT, glad to have you..
when you say rex si, are you referring to a b16 swap in your rex?
if so you could use the greddy kit.
#1- depending on mileage, i would say do a leakdown and compression to see if engine is up to par.
#2- you should be fine @ 7psi on stock internals
FYI, search in archived sections and a vast amt of info can be found.. not being a dick to you just helping you out..
hope that helps ya
hope that helps ya
The CRX SI had a sohc non-vtec motor. Never the less it has the same d16 block that most d16s have. Ive run 15psi, and heard of 18psi, on stock d16 blocks. Altohugh i dont recommend that. I run 10-12psi daily on pump gas...on a stock block.
But whatever you run..tuning is key. You could easily blow it up at 4psi with bad tuning. But with good tuning (and a good motor) you will have a happy relationship.
liam
liam
i have a d16 in my Rex for now. i savin' up $$ for a B16a swap but thinkn of going turbo. i heard that turbon' a SOHC motor should only give about +/- 50hp?? is that correct?? should i get the b16 of go turbo??
A turbo sohc is going to make more power/torque (if turbo is sized right) but going to be less reliable. B16a is a stock motor..its going to last forever it taken care of.
What do you want to do with your car? Thats a question only you can answer.
liam
liam
looking reliability and fun. my friend has a turbo gsr and says it a
to maintain.Trending Topics
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
In your case in particular, I would just go for a b16 swap, turbo are sometimes a overkill of what you might actually need. Especially if you don't feel like maintaining it. Less problems in the future as well. Take it slow, turbo will come sooner or later for you if you want it bad enough. But do it when your ready, dont 'just jump into it. I know that's hard but... take your time.
It's like a relationship with a girl. If you are a guy I dunno. But my guy friends are allways falling for girls, and I say take it nice and slow, don't go all head over heels, cuase you never konw if it's is goign to work out the way you want. And when it doesn't work out (it never does) they all come crying back and all sad for weeks. Always just jumping into it when they aren't really ready or when they dont' really know how it's goign to be. It just that they have been bitten by the love bug or whatever. Just like poeple get bitten by the boost bug. Relationship that are rushed don't work out. Turbos that are rushed don't work out. Then I say, "you're a stupid ****, and nobody ever listens to me when I tell them to take it slow."
Well... yeah.. I think.. I wen toff on a tangent there, but I hope that might have helped. I'm bored, it's 7 am, and I haven't gone to bed yet.
liam
99_red_si
Feb 22, 2008 05:21 PM
