TURBO MOUNTING
Old Mar 11, 2013 | 10:27 AM
HONDATAD16's Avatar
Default TURBO MOUNTING
I have 95 eg with d16. car has spoolin performace ac friendly turbo manifold and precision 6031 turbo. turbo is mounted with inlet facing passenger side of car. can I turn turbo around so inlet is facing driverside? Dont beat me up to bad new honda owner. Thanks
Old Mar 11, 2013 | 10:32 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: TURBO MOUNTING
Not with an ac manifold, no. The way the flanged is clocked the turbo wouldn't even bolt up all the way
Old Mar 11, 2013 | 10:41 AM
HONDATAD16's Avatar
What manifold should I use? I bought the car set up this way. doesnt have ac. I dont like turbo inlet being so close to radiator.
Old Mar 11, 2013 | 10:52 AM
wantboost's Avatar
Who is Mr Robot?
A non ac one.....
Make an intake for it to draw cool air from outside the engine bay
Old Mar 11, 2013 | 11:00 AM
HONDATAD16's Avatar
If I use non ac can I then rotate turbo so exhaust side and radiator heat are on same side of engine bay. With current header turbo very close to radiator and inlet pipe has to cross horizonaly behind radiator. Is it possible to move radiator with h22 radiator relocation brackets to where ac condensor used to mount then I could build cold air intake with behind bumper air inlet.
Old Mar 11, 2013 | 12:18 PM
wantboost's Avatar
Who is Mr Robot?
It shouldn't have to go behind the radiator.... they have these things called bends
And yes, if you get a non ac compatible manifold you can turn the turbo around.
p10hlm
Apr 19, 2012 08:26 PM
kyle741
Mar 19, 2012 01:19 PM
inh
Sep 30, 2007 04:01 PM
