Turbo manifold question? drag/greddy/revhard for h22?
Do drag/greddy/revhard do a turbo manifold for the H22 engine? And is it possible to buy these seperately?
Thanks
Thanks
Re: Turbo manifold question? drag/greddy/revhard for h22? (BigBlockH22atch)
$695 for the Revhard. It has equal length tubes and a thick flange. The exhaust to spin the turbo comes from a collector area instead of a single tube. (much better)
I bought it in Jan of 04 and I heard prices went up some since then. Got it through a local shop. You should be able to do better than I did.
Re: Turbo manifold question? drag/greddy/revhard for h22? (ben@importparts.com)
A number of Hondas,at the dyno shop I use, using a single exhaust runner to mount turbos(one runner to spin the turbo) had problems. - about half??
Re: Turbo manifold question? drag/greddy/revhard for h22? (purpleh22)
How would you only use one runner to spin the turbo? If you're referring to the Drag cast manifolds, all 4 exhaust ports feed the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 »</TD></TR><TR><TD CLASS="quote">A number of Hondas,at the dyno shop I use, using a single exhaust runner to mount turbos(one runner to spin the turbo) had problems. - about half??</TD></TR></TABLE>
Re: Turbo manifold question? drag/greddy/revhard for h22? (AP-Signworks1)
will a h23 manifold fit a H22 head? If not how much modification would it take to make it work. I am asking because I have a Drag manifold for a H23
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">will a h23 manifold fit a H22 head? If not how much modification would it take to make it work. I am asking because I have a Drag manifold for a H23</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockH22atch »</TD></TR><TR><TD CLASS="quote">will a h23 manifold fit a H22 head? If not how much modification would it take to make it work. I am asking because I have a Drag manifold for a H23</TD></TR></TABLE>
wont work. huge difference in port size/placement. and bolt placement.
Re: Turbo manifold question? drag/greddy/revhard for h22? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">
wont work. huge difference in port size/placement. and bolt placement.</TD></TR></TABLE>
Thank you for the prompt answer.
