Turbo LS : Sudden loss of power and boost
All,
I have a 2000 integra with an LS-T. Completely stock motor with drag kit. Kit consists of Drag mani, turbonetics 57 trim, Tial WG and Ebay intercooler, DSM injectors and Walbro pump. 2.5 DP and exhaust
Car has been boosted for almost a year now with no issues. This is my daily driver and not abused at all. Ran beautiful. A few days ago as I was accellerating the car seemed to hit a wall. TOTAL loss of power. Seemed to do it consistently at 10 psi (MBC was set to 13) but still does it on lower boost running off the spring. Only happens after being WOT for like a second or 2. Went for a drive with my buddy who did the turbo install and tuning and he says it is boost cut. Boost cut is set at 15 psi and car is now only running off 7lb spring after removing the MBC and still does it. The car just totally loses power and boost just drops. No accellerating possible unless I let off the gas.
Eliminated the MBC to only run off spring and same thing. Checked and took apart the WG and all seems fine with it. Changed vacumm sources to the WG and still the same. Verified that boost cut is at 15psi. Reburned chip and installed. Same problem. It's not like the car breaks up, it just loses all power and boost drops. I have checked piping and all is secure and in place. My buddy says its possibly a bad MAP sensor although I am running an Omni MAP that is only a few months old. What could be causing this? What should I look at? Has anyone ever experienced this before? Before I spend $125 on a new map, would a faulty one cause this?
Car makes boost nice and smooth to the 7 lbs but once its at full boost with me at WOT for like a second or 2 it totally dies. Any suggestions or advice would be greatly appreciated.
Thanks all.
Jaysem
Thanks all.
Jaysem
Re: Turbo LS : Sudden loss of power and boost
So it's not like it does it every time you reach regulated boost pressure, right? Or, does it do this like every time you reach regulated boost which would be for you, from what i've read, about 7 to 8 psi?
Also, is your rev limiter SOMEHOW activating early? It isn't misfiring when it does this, or does it? Does the car run like it's not boosted when it does this, such that we can eliminate any little problem that might be occurring with the turbo?
These questions might help. Hey, it could be your MAP sensor, but I don't know.
When driving the car normal and not reaching max psi, the car runs like it always has. Car will make the boost nice and smooth as always but then hits thsi wall as soon as Im on it for a few seconds at max boost. No breaking up no misfiring, nothing.
Car just dies and coasts. No breaking up at all. Once the loss of power hits, I can no longer accellerate or anything, even if I keep my foot on the gas at WOT the RPM's just continue to drop as if I put the car in neutral and was coasting. In order for me to be able to accellerate Ihave to take my foot off the gas and then get on again.
sounds like the car is sputtering.....i had a similar problem when I hit WOT my car would be stuck as if I was hitting the rev limiter. I ended up changing my plugs NGK part number 6097 and distributor and the problem was gone. Good luck
Was thinking of doing that anyway since I havent changed them since being boosted. Hopefully it's something as quick as that! So you're car was doing the same thing?
Shame on you.
Definitely change them out if you've had them for nearly a year being abused. Not sure if that will cure what your engine is doing, but for such a cheap fix ($10), not going to hurt to attempt.
Wheres my titleeeee!
Hit me up . Im in west haven 215-8996. i had the same issue with a single cam (did you check and see if your TPs is off?) And what size map sensor are you running?.
I'll let you guys know how I make out. Thanks
Changed my plugs and so far so good. I fail . Done numerous pulls and no symptoms yet. Keeping my fingers crossed. Hope this does it. When I pulled my old plugs, a couple of them had a bunch of oil on them. Is this anything I should be worried about or just normal for some plugs that should have been changed out a long time ago?
Thanks to everyone for their help.
check your new plugs after like a day. you may have oil leaking through the spark plug tube seals. mine need to be replaced. I'm hoping it's just the upper ones because i don't feel like taking the head out to do the bottom ones.
Originally Posted by HamiltonRex
Bottom ones?
Lol i most definitely did not mean the headgasket. I just remember reading online and through manuals that there are 2 sets of spark plug tube seals. It is much more common for the ones pressed into the valve cover to need replacing, but i was pretty sure in the readings it said there is another set that can only be reached if you remove the valvetrain...maybe i have it mixed up with something else. if you guys know what i might have it confused with, let me know. i'll look it up again.
Little bit of oil on both. Only a couple of them had oil on them but it was on the electrode and on the threads.
Spark plugs Same thing happened to me a while ago, my roommate was driving behind me and saw fire pop out the exhaust.
FYI, I change my NGK-BKR7E plugs with every oil change.
Car is acting up again. I put the MBC back on and put the boost back up to 13. Got on the highway today and it did the same ****. Not as bad though, it lost power but starting building boost and accellerating if I kept my foot on the gas but would die a couple seconds later. I bet my plugs probably have oil on them. I'm going to pull them out and replace the VC gasket and the tube seals and get another set of plugs.
If I still continue to get oil on the plugs, what is the next step? valve seals? piston rings?
Give the igniter in the distributor a try.Swap it with another one,used is fine.I chased a "boost cut" for a while until someone said to try the igniter.It would cut out at 6k under boost,just like you describe.I put a junkyard one out of a smashed distributor and it cured it.
It probably is something in the ignition. Since you changed sparkplugs, you've still got plenty of things to check. Plug wires (I had a misfire with a bad one, but nothing like what you are going through), cap/rotor/contacts, ignitor, ignition module, etc. Distributor issues suck. Hopefully you can figure it out.
Well, before doing anything drastic, do compression and leakdown tests. It's probably harmless oil, but the tests will tell you most of what you need to know.
For the leakdown test, when you pressurize the cylinder with the air, and see good numbers through the gauge (<10%), then you're fine. If one is bad, you'll be able to hear what the problem may be.
If you hear (you'll faintly hear it, so listen carefully) the compressed air in the exhaust pipe, exhaust valve(s) are in poor condition. If you hear it intake (disconnect the charge pipe and listen through the throttle body), then your intake valve(s) are in poor condition. If you can hear the compressed air coming out of the crankcase (open up your oil fill), then the ring(s) and/or headgasket are probably in bad shape.
Hopefully it's not a distributor issue since this one is less than 1 year old. Im going to replace the tube seals since the oil is on top of the plugs.
Dont think it is a HG since I dont have any overheating issues or mixing of oil and coolant.
Before I get to ahead of myself I'll start with thos tube seals and go from there.
Thanks to all for their advice and help.
-Jaysem
-Jaysem
