turbo ls problems
Old Feb 15, 2009 | 10:29 PM
8083tcman's Avatar
Default turbo ls problems
my car is running 10lbs boost when i bought it put it was running crappy when i gas it so i bought 310cc injectors and the car is still doing it should i raise my fuel pressure? also is a air fuel gauge worth buying?
Old Feb 15, 2009 | 10:36 PM
project dc2's Avatar
Default Re: turbo ls problems
oh wow .. you need a lot more understanding of what you're doing.
chances are .. possibly you blew your motor already or cracked some ring lands
what does the car do ? does it emit a lot of smoke ? bog? die down?
adding 310CC injectors isnt going to help the cause, especially without any sort of ecu tuning.
we need a better understanding of what you acutally have. what modifications. maybe a pic of the engine bay will help us help YOU determine what you have or what your problems may be
Old Feb 15, 2009 | 10:49 PM
8083tcman's Avatar
ok i first of all we put a chipped ecu in and it still was leaning out. also it idles up and down..
Old Feb 15, 2009 | 11:57 PM
Silva Bullit DC4's Avatar
You bought a boosted car WITHOUT a chipped ECU??? Did it have stock injectors???
Post everything you have in your setup, too much info is not being stated for someone to help you. In any case, you need to get that thing to a tuner ASAP before you ruin your engine, IF you havent done that already.
lsturbo*
Aug 17, 2009 10:11 AM
track_assassin
Dec 15, 2007 05:17 AM
Mtzpepe
Mar 6, 2007 12:35 PM
D_CRX_Si
Apr 28, 2006 04:36 AM
Dan_the_MaN
Oct 24, 2005 10:40 PM
