Turbo kit!?
Old Apr 18, 2006 | 08:53 PM
VTECth1s's Avatar
Default Turbo kit!?
i came up on a Greddy D-series turbo kit, but i got a LS/VTEC what exact parts do i need to swap out, so that the turbo kit can be bolted on?? thanks?!
Old Apr 18, 2006 | 08:59 PM
VTECth1s's Avatar
Default Re: Turbo kit!? (aallbbeerrtttttt)
different turbo manifold and bigger turbo that fits it of course, and everything else is good to go, piping, intercooler...etc??
Old Apr 18, 2006 | 10:07 PM
Group Tenacity's Avatar
Default Re: Turbo kit!? (V8-eater)
You will need to change out the manifold, turbo, and down pipe for it to work... I think your best bet would be to sell that kit and use the money to buy a kit for a B series...
Mike...
Old Apr 18, 2006 | 10:11 PM
dpetro1's Avatar
Default Re: Turbo kit!? (Group Tenacity)
truthfully i dont think anything is gonna really work. you are gonna have to change the mani and downpipe for sure. turbos are pretty much universal so you could use it if you want. as long as the mani is flanged for it. after making all those changes the ic piping and oil lines probably wont be spot on either so they might need some modification.
IMO not really worth it. plus like someone said, that turbo is probably a bit small for an ls/vtec anyways.
Old Apr 18, 2006 | 10:18 PM
Default Re: Turbo kit!? (dpetro1)
When i switched over from D series to B series, i used the same greddy turbo kit that i was using on the D series motor, but i did have to change the manifold, turbo, and down pipe...
the manifold wont bolt up obviously, the turbo was way too small for what i wanted, and the down pipe wouldnt clear the oil pan... everthing else in the kit worked just fine...
Mike...
Old Apr 19, 2006 | 05:56 AM
Schister66's Avatar
Man U FTW
build a kit by yourself....its not that hard
EGcivicBoy
Dec 31, 2003 08:36 AM
ChrisAnF1892
Apr 14, 2003 12:05 PM
B18PoweredCivic
Oct 20, 2002 11:01 PM
SiREF8
Jun 6, 2002 07:47 PM
