Turbo Integra mpg
Forged bottom end b18. 9.8:1 or 9.2:1 compression bored .25 over stock. Stock head. Run 93. As a daily i average about 14mpg mostly stop and go traffic with an occasional wot pull on the way to/from work.
curious if that seems really low/bad? My afr at idle is pretty good around 14.7, light throttle cruising afr is also more on the lean side. Car was tuned by Evans tuning so i trust his tune is good but not sure what others get dailying a turbo honda
How much power?
My S2000 was on a 5558 @ only 10PSI, probably low to mid 300s, and I think I was only getting about 15MPG on that. I questioned the tune a bit, but I definitely don't think I was running rich.
To be fair, that could at least be a small factor lol. 15mpg average in my S2000 in city driving, which isn't totally awful on those cars but I'm sure the tune could have been optimized a lot better - It was a street tune on AEM.
About 360hp.
i guess ill try staying out of boost more and see how that affects it. I figure if im getting hypothetically in the 20s cruising, the minute i WOT im basically negative mpg so it averages out...idk
I was able to do 400 miles on 1 tank of 93 with my ek turbo 11:1 b16. GT2871. Pretty much 40mpg highway. It would get 30+mpg around town no matter how hard I drove it. My realistic average highway was more like 35-36mpg.
curious what wheel/tire setup you had? I run 17x8 with a 225/45 all around so maybe that extra rubber + taller wheel isnt helping either
When I saw 40mpg for sure one time I was going from Chicagoland to Colorado. Had some friends in an SUV following, everyone surprised lol. I used the GPS distance back to our starting point, and the gallons of gas it took at the station.
i just calculated from 2 tanks and how many gallons i put in. I think i averaged like 200 ish miles cant remember how many gallons i put in. Ill have to be more accurate this next tank
