turbo integra ls tuning
Old Feb 7, 2006 | 07:43 PM
orangecrx's Avatar
Default turbo integra ls tuning
Hey I have a integra ls that im going to turbo. i have already bought most of the stuff i need for it. im wondering about injectors and a tune. who can i talk to about getting my ecu reflashed. the car is a 96. also, what size injectors are you guys using. i plan on 6 -7 psi to start. thanks for your help guys -Eric
Old Feb 7, 2006 | 08:48 PM
rsintegra's Avatar
Default Re: turbo integra ls tuning (orangecrx)
Injector size depends on the amount of HP you want. Boost doesn't tell us how fast your car is at all. 6-7psi on a T67 is waaaay different then 6-7psi on a T3. Make sense?
Old Feb 7, 2006 | 09:16 PM
.dave's Avatar
i HAS questions ?
To control the larger injectors, you'll need a modified ECU program. The easiest way to do this is convert to an OBD1 ECU (you have an OBD2a ECU right now) and run Hondata/Neptune/Crome/etc. You will also need a jumper harness to plug the ECU into your current wiring harness. More than likely you'll want 440-550cc injectors with the power level that you'll see at that boost. I'd recommend getting a set of saturated injectors as you won't have to wire in a resistor box and can convert to stock fairly easily for emissions testing etc.
I'm assuming Amity Harbor is in the Long Island area. PM Xenocron, he is in New Jersey I think and offers everything from chipped ECUs to tuning. He should be able to help you out quite a bit.
ZoominNewman
Jan 30, 2011 06:23 AM
ickyhonda
Mar 1, 2008 07:02 PM
mattm868
Aug 18, 2007 06:31 PM
rsdriver17
Sep 6, 2006 11:46 AM
crxkid24
Oct 13, 2005 08:09 PM
