turbo intake or exhaust manifold? need help 14b mitsu for b18c teg
Guest
Posts: n/a
Re: turbo intake or exhaust manifold? need help 14b mitsu for b18c teg (synik)
do i go with the intake manifold or the exhaust manifold? i have a 94 teg with a b18c i thought that you only need the exhaust manifold to run the turbo off ? i have a 14b turbo from a 97 mitsu help please i know nothing!!!
Re: turbo intake or exhaust manifold? need help 14b mitsu for b18c teg (noobical)
lol this is a funny post.
Exhaust manifold goes to the turbo. After the turbo is intercooling piping, the intercooler, then back to the throttle body, into the intake manifold.
Go to http://www.turbobygarrett.com and click turbo tech, and read turbo tech 101, 102, and 103. Then read them a few more times till you understand everything really well. Good luck
1 Post
Re: turbo intake or exhaust manifold? need help 14b mitsu for b18c teg (LeGeND4LiFe)
just so u know u just can't slap a turbo kit on, i read lots and learned to understand it all, i've sseen some people just slap a turbo on and not know anything used stock injectors and noe fuel management motor went at 4 psi, it was funny cuze we hate him but don't waste ur money do it right the first tiem, and if u are doing a home/made turbo setup go with a 16g instead a 14b pushes alot more CFM, just some of my 2 cents
Re: (noobical)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noobical »</TD></TR><TR><TD CLASS="quote">no **** bro!! alli need is a exhaust manifold i got everything else !!</TD></TR></TABLE>
Please list what you have
what size inejctors? And is your only tuning method the SAFC? If so, I would recommend getting yuor ecu chipped and tuend with a proper EMS. One taht doesn't skew the map signal to alter fuel trims.
Re: (noobical)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noobical »</TD></TR><TR><TD CLASS="quote">boost and air fuel gauges, turbo timer, SAFC, fpr, oil cooler,all piping,fmic,oil lines, td05 14b turbo with internal wastegate, etc..... </TD></TR></TABLE> For having all this stuff you sure are pretty stupid with turbo goods.
Guest
Posts: n/a
Re: (SiKid86)
bloW me ur stupid sKid C===8
NooBical just pimp slapped you! you have offically been nooBical pimp attacked! you dickass
Modified by noobical at 5:02 PM 10/3/2006
Modified by noobical at 5:04 PM 10/3/2006
Modified by noobical at 5:06 PM 10/3/2006
mkw1
Welding / Fabrication
34
08-11-2008 04:43 PM
