Turbo Idle l Issues
Old 12-01-2003, 04:56 AM
abeaujuin's Avatar
Default Turbo Idle l Issues
I have installed my Drag 4 kit on my 94 accord. My car will not stay on. I noticed that the MAP has a hole on the side of it. When I clog it, the car idles fine, but when I give it gas, the car shuts off.
When I unclog the hole on the side of the MAP, the car will shut off and idle ruff, but will stay on when I give it gas. I don't know what to do now. Can someone help me on this?
I installed the intake fuel pump, FMU, Connected the Vacuam hoses, etc... It sounds like something is up with the MAP.
Old 12-01-2003, 05:10 AM
dennis's Avatar
Default Re: Turbo Idle l Issues (abeaujuin)
do you have a vac/boost gauge hooked up? That'd be the first thing I'd check to see that you're within the limits.
Old 12-01-2003, 05:22 AM
abeaujuin's Avatar
Default Re: Turbo Idle l Issues (dennis)
No I don't have a boost gauge hooked up. I also didn't hook up the O2 Sensor, drags downpipe hole for the O2 sensor is to far back I don't have any clearance to install the O2 Sensor.
Old 12-01-2003, 05:55 AM
30psi Teg's Avatar
replace your map sensor
Old 12-01-2003, 06:17 AM
abeaujuin's Avatar
Default Re: Turbo Idle l Issues (30psi Teg)
This is a brand new MAP sensor. What is the hole on the other side of the MAP sensor for? It is sucking in air I noticed.
Old 12-01-2003, 06:54 AM
99B16Si's Avatar
it shouldnt be sucking in air thru the MAP. something is wrong with that thing and your MAP is getting the wrong readings because of it which will definitely screw up your idle
Old 12-03-2003, 07:05 AM
abeaujuin's Avatar
Perfect it was the MAP sensor, thanks for your help.
aligntv
02-14-2017 06:16 PM
supercharged d
01-27-2010 01:55 PM
92civicx
10-12-2007 04:48 PM
89 CRX SI
04-15-2004 11:00 PM
Quick Reply: Turbo Idle l Issues
