Turbo help
Old Feb 6, 2002 | 09:35 AM
The Brown Kid's Avatar
Default Turbo help
I cant get the oil sending unit bolt off so i can tap my engine for oil. I like cant even see what Im tryin to take off. Its the bolt with the plug with 1 wire going to it right?? Can anyone help me out. Also what radiator could i use to have hood clearance on my hf crx<89> I have a 92-95hb radiator but is there anyway can get that fit so my hood wil close??
Old Feb 6, 2002 | 09:45 AM
Doodoo's Avatar
Default Re: Turbo help (Iron Flag)
The radiator you have to chop the front crossmember so that it will drop a couple inches. I have also heard people angle it back also. If you chop the cross member you have to make new brackets for the bottom mounting tabs.
I would take off the oil sending unit and nothing else to tap your feed line. I think its a 19MM. Use the force.
Old Feb 6, 2002 | 09:55 AM
RGAZ's Avatar
New User
Doodoo is right. The single wire sender on the back of the block should come off easy.
The radiator won't fit without cutting the lower cross-member. I just tilted my radiator back about 1 inche and the pipes allow the intercooler to fit there (no AC of course). Someone has adapted a VW radiator to fit with no cutting, but I haven't got the model number yet.
Check the site below for radiator relocation instructions.
Good luck.
Randy
Old Feb 6, 2002 | 09:58 AM
Pritos's Avatar
New User
I got frustrated trying to remove the oil sending unit with the filter in place. Just make this a chance to change your oil and when your filter is removed, you'll have ALOt more room to wiggle around a good sized tool to remove it.
[Modified by Pritos, 10:59 AM 2/6/2002]
g0tgot
Jan 17, 2011 07:06 PM
tEKnics
Oct 15, 2009 11:12 PM
BoostdRex
34
Aug 15, 2005 08:15 AM
btole
Mar 24, 2004 03:16 PM
