NEED HELP WITH TURBO???????
Re: NEED HELP WITH TURBO??????? (team_lunatics)
did you put a different fuel pump in the car when u put the turbo on because if the fuel filter gets dirty at all it will just make the motor boog when it hits boost
I know why!
It's either cuz you have an H22 or because it's a Honda. Or because it isn't an LS1.
hahaha
Just kidding man, where's your VTAK engagement set at currently?
Also, it's probably got something to do with the tune you currently have on it, whether it may be a basemap or whatnot.
And if you DON'T have a tune....well....you may wana get one first of all. Secondly...it's maybe because you're pushing over 11psi (If you're at sea level) and hitting factory fuel cut (Yeah, when the stock map sensor sees 11psi, it'll start rev limiting...I went through that **** too).
hahaha
thanks everyone with their knowledge. you think i need to put those gm 3bar map sensor? i do have the stock map sensor on right now.
you dont really "need" a gm 3 bar.
Although, it would be nice.
But if you just want to bypass it, just go buy this "missing link" from synapseengineering.com
It's a one way bypass valve, so your stock map sensor sees vacuum but not boost. And it doesn't cost much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team_lunatics »</TD></TR><TR><TD CLASS="quote">thanks everyone with their knowledge. you think i need to put those gm 3bar map sensor? i do have the stock map sensor on right now.</TD></TR></TABLE>
probably not.
but 20th anniversary trans am if you want it
probably not.
