Turbo or head support brace??
Old Jan 24, 2009 | 06:25 PM
kte324's Avatar
Default Turbo or head support brace??
I have searched. The turbo, manifold, wastegate, downpipe, etc. are pretty heavy. And I dont believe honda designed the heads to be carrying so much weight. Is there some type of brace that can be mounted on the turbo or any of its parts to support the weight?
Old Jan 24, 2009 | 06:28 PM
redboost10's Avatar
Default Re: Turbo or head support brace??
you can make a heim joint off the turbine. i think atpturbo makes a nice little bracket that utilizes the bolts holding the turbine on the oil housing.
i seriously dont think its needed. not sure what type/brand of manifold your running, but there are many people on here running a sch 10 manifold with a 40 lb turbo and two wastegates with no brace with no problems.
Old Jan 24, 2009 | 06:31 PM
NJIN BUILDR's Avatar
I haven't seen one available off the shelf,but I have seen some that were fabricated.It doesn't seem to be any problem without one.Pretty rare to see one.
Old Jan 24, 2009 | 06:35 PM
redboost10's Avatar
this is what i was talking about. bolt this to the turbine then use a heim joint and make a bracket coming off the head. i have a heim joint if your interested, but like mentioned, not needed at all.
Old Jan 24, 2009 | 06:41 PM
SovXietday's Avatar
If you're manifold is up to snuff, you should have no problems supporting the weight of even the larger turbo's.
Just don't expect a ching chang super duper polished childrens toy manifold to hold up for very long without some serious bracing and very little heat application.
Old Jan 24, 2009 | 07:01 PM
kte324's Avatar
Oh I have a nuekin ramhorn with precision sc61, etc. I have ran the car like that for about a year and a half I was just seeing if there was something out there for support.
Old Jan 24, 2009 | 08:09 PM
blinx9900's Avatar
Your just itching to modify something, you can do it but not really needed, if anything it would take load off the manifold. The only upgrade needed is if you have bolts (mostly obd2 engines) you can convert them to studs.
Old Jan 25, 2009 | 05:40 AM
kte324's Avatar
Your right I am looking to modify something, or make something last longer by being stronger. Well I was thinking of it as we put sleeves in our engines so that we can turn up the boost, but we dont add braces so we can hang stuff off of our engine heads.
Old Jan 25, 2009 | 06:46 AM
DaveF's Avatar
here is a support brace i use for my 45lb turbo (not to mention 2 wg's + heavy manifold) so far its been holding up well.
Old Jan 25, 2009 | 09:11 AM
Garage 808 Hatch's Avatar
[QUOTE=DaveF;37146368]here is a support brace i use for my 45lb turbo (not to mention 2 wg's + heavy manifold) so far its been holding up well.
I take it you have solid mounts??
Old Jan 25, 2009 | 09:22 AM
DaveF's Avatar
driver side mount
mid plate
Old Jan 25, 2009 | 09:58 AM
kte324's Avatar
Whoa. Thats what im talking about, but my car is a street car.
Old Jan 25, 2009 | 12:39 PM
blinx9900's Avatar
Originally Posted by DaveF
What kind of engine does your turbo have? Is that a B series with the alternator mounted in the front?
Old Jan 26, 2009 | 01:18 AM
DaveF's Avatar
yes, its part of a z10 engineering kit. its a b series.
Old Jan 26, 2009 | 10:40 AM
SovXietday's Avatar
Showoff.
StolenTeg
Apr 19, 2008 11:11 AM
danielm3
Welding / Fabrication
21
Aug 19, 2007 11:43 PM
turbotime
Apr 30, 2007 12:51 AM
DIY_Racing
Jan 1, 2003 05:49 PM
DIY_Racing
Apr 29, 2002 01:40 PM
