Turbo H22 block breather help....
From what I understand the h22 has poor "circulation". I had read some stuff about the vacuum line, etc.. But I cant find it anymore. All help is great. I just turbo'd it about 1 week ago so I want to get it airing out properly.
Thanks...
Thanks...
Re: Turbo H22 block breather help.... (BigBlock)
Here you go chris I will help you out.
https://honda-tech.com/zerothread?id=1199935
And here is another: https://honda-tech.com/zerothread?id=1197655
I'm ready to run anytime you are
Re: Turbo H22 block breather help.... (Speed-Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed-Factor »</TD></TR><TR><TD CLASS="quote">Here you go chris I will help you out.
I'm ready to run anytime you are </TD></TR></TABLE> the BIGBLOCK KILLER!!!!!!!!!!!
the only way to do it with H series it seems Is to Use the Valve cover, i just had mine painted so its out fo the question...
There isnt a way to do it thats similiar to the B series stuff that i know of.
Matt
Matt
Re: Turbo H22 block breather help.... (This One)
is it ok to just drill a hole in the valve cover and weld a AN fitting on it (inside and out) with a hose connected to it and just have it going to the bottom of the car?
Yeah, sounds good. Let me just work a few bugs out., right now I'm too slow
Thanks for the info....
Re: Turbo H22 block breather help.... (1bigdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bigdog »</TD></TR><TR><TD CLASS="quote"> the BIGBLOCK KILLER!!!!!!!!!!!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlock »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>its all good have fun
i gutted my pcv valve and ran the line from there to the catchcan and from the breather to the catch can. i drilled a hole in the catch can and stuck a filter on there....
i took my pcv valve and system out flung it in the garbage then took my valve cover and drilled and tapped 2 fittings into it then that went to a endyn catch can also took 2 k&n small filters one to the valve cover where the original rubber hose to the intake arm went and the other is where the pcv valve used to be works good so far and my catch can dont fill up like some people say
bb4socal
09-02-2006 07:16 PM
