turbo gsr (where dose the water inlet/outlet plug to the block for a BB turbo)
post up pic or give me some info on it...getting my project set up n going by next spring..pic will help out alot!!thanks
Re: turbo gsr (where dose the water inlet/outlet plug to the block for a BB turbo)
are you asking about how to run the water lines to the turbo? there is tons of info on this (and its not just for ball-bearing turbos)
https://honda-tech.com/forums/showth...ighlight=water
https://honda-tech.com/forums/showth...hlight=coolant
https://honda-tech.com/forums/forced-induction-49/turbo-coolant-line-kits-w-black-fittings-2014711/
good pic..i see the front plug for the water but where dose the other outlet gose???or im i not seeing it in the pic??
outlet probably goes to the bottom of the radiator. You may need to weld a -6AN aluminum bung in there.
