Turbo Gasket Question
Old Feb 16, 2004 | 04:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Turbo Gasket Question
This may be hideously ignorant of me, but I'll ask it anyway.
I know I will need a gasket between the turbo and the manifold. I bought the T3 downpipe flange from atpturbo.com. Is there any gasket that is supposed to go between the turbo and the downpipe flange?
Old Feb 16, 2004 | 04:34 AM
yellowturbo's Avatar
A t3 gasket will be good, look at atpturbo you will find...
Old Feb 16, 2004 | 05:07 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (yellowturbo)
I looked again, but all I found was a turbo inlet gasket or a turbo outlet gasket for a T3 using an internal wastegate [the 3 bolt gasket]...I am needing to know if there is a need for an outlet gasket, particularly for use on a T3 exhaust housing using an external wasategate flange [if it exists, a 5 bolt gasket]. Here, I need to know if I'll need a gasket between this and the turbo:
Old Feb 16, 2004 | 05:22 AM
notoriousB's Avatar
you can use high-temp copper silicone between the turbo and the downpipe to seal it...
Old Feb 16, 2004 | 11:17 AM
DaX's Avatar
DaX
Loved
Community Favorite
Can this be bought at Auto Zone or is it a special order from mcmaster.com?
Old Feb 16, 2004 | 11:21 AM
TurbodCX's Avatar
Default Re: Turbo Gasket Question (DaX)
You do not need a gasket between the DP and the Turbo housing. You really dont even need one between the manifold and the turbo either. I dont use gaskets anywhere on my setup. been fine for 2 years now. Gaskets will just blow out over time. GO WITHOUT them,
HTH
Brian
Old Feb 16, 2004 | 11:23 AM
TurboTegB18c's Avatar
Default Re: Turbo Gasket Question (TurbodCX)
I have been using NO gaskets on all my turbo/main turbo/dp setups.
Old Feb 16, 2004 | 11:24 AM
b18bturbo's Avatar
Default Re: Turbo Gasket Question (TurboTegB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTegB18c &raquo;</TD></TR><TR><TD CLASS="quote">I have been using NO gaskets on all my turbo/main turbo/dp setups. </TD></TR></TABLE>
same here
Old Feb 16, 2004 | 11:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
Then I guess I'll save the $8 for the turbo/manifold gasket and also forego the turbo/downpipe gasket. Thanks guys!
Old Feb 16, 2004 | 01:32 PM
grndcont's Avatar
ya, it's too hot for gaskets in that area.
Old Feb 16, 2004 | 02:08 PM
JrCRXHF's Avatar
me too it works alot better...
Old Apr 3, 2005 | 05:15 PM
jdmturbosol's Avatar
hondabond ht
Old Apr 3, 2005 | 06:27 PM
drumking15's Avatar
or you get really **** and custom make all your gaskets out of copper flashing
Old Apr 3, 2005 | 08:52 PM
AspectIndustries's Avatar
Default Re: (drumking15)
My honest opinion. Dont use gasket at all! They all tend to burn, i hate them!
Old Apr 3, 2005 | 08:58 PM
Raunch's Avatar
Default Re: (synik)
No gaskets here either. Best way, just make sure everything is nice, even and tight.
Old Apr 3, 2005 | 09:39 PM
BoostedJeff's Avatar
Default Re: (synik)
i use a copper gasket for my manifold/turbo.
Old Apr 4, 2005 | 07:25 AM
Slick GS-R's Avatar
Default Re: (BoostedJeff)
This is what I used:
Good ****!
Old Apr 4, 2005 | 07:49 AM
Evanmb44's Avatar
Default Re: (Slick GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick GS-R &raquo;</TD></TR><TR><TD CLASS="quote">This is what I used:
Good ****! </TD></TR></TABLE>
i use this stuff too. it works greeat
i also hate gaskets....ive had so many problems with them blowing out and burning...then everything gets loose and tries to fall off....i think i will be going without them now
Old Apr 4, 2005 | 08:34 AM
Civicman86's Avatar
Carbon will build up and create a gasket for you
norcalB18
Oct 14, 2010 10:38 PM
dester223
Dec 16, 2005 08:26 PM
Johnny_Rocket
Jun 30, 2005 06:10 PM
BoostedEX
Jul 1, 2004 12:59 PM
youngkow
Apr 8, 2003 08:12 PM
