turbo feed leaking oil what size fittings?
just trying to save some time so i can buy the fittings and not have to walk to the store with my old fittings in my hand.
one of my feed fittings is slighlty dented and causing a leak. i have a 3AN line but need to know what size is below that.
tried searching but way to many drain and block fittings are coming up causing confusion in my head.
also what are you guys using to seal the fittings? teflon tape? i think the teflon tape is melting from the heat of the turbo???
TheIntegraGuy
08-21-2005 11:01 AM
