Turbo engine too loud......problem?
Old Nov 4, 2001 | 01:58 PM
shamoo's Avatar
Will you make something up for me please?
Default Turbo engine too loud......problem?
My friend and I just installed the Drag III kit in my 97 LS. It hasn't been driven yet, but started up on jackstands to see how everything went.
It is way loud, sounds like a harley at idle. It seems as the wastegate is always open dumping exhaust out of the dumptube all the time. Is that supposed to happen or was the wategate hooked up wrong?
Thanks....hope to be boosting by tonight.
Old Nov 4, 2001 | 02:01 PM
paulzy's Avatar
Default Re: Turbo engine too loud......problem? (shamoo)
is the dump tube dumping into the atmoshpere or the downpipe? Is the down pipe hooked up to the exhaust? Try playing with the top port of the wastegate(adjust it) and see if that makes any difference...
Old Nov 4, 2001 | 02:03 PM
LsTurbo91's Avatar
hmm the wastegate should not be open at idle, it needs boost pressure for it to even open, and the spring on there is pretty stiff. I would look for an exhaust leak, thats probably what it is.
Old Nov 4, 2001 | 02:10 PM
ekb18c's Avatar
Default Re: Turbo engine too loud......problem? (LsTurbo91)
yup.. you probaly got an exhasut leak somewhere. Is the manifold bolted on tight? If yes then look for other leaks..
HTH
Old Nov 4, 2001 | 02:26 PM
shamoo's Avatar
Default Re: Turbo engine too loud......problem? (ekb18c)
I don't think it's a leak. Is there supposed to be a gasket type deal between the turbo and the downpipe? I don't have one on there because none was supplied.
The sound I hear is exhaust coming out of the wastegate though. My friend who hooked it up hooked up both lines coming out of the Deltagate. I told him (I'm not sure, but I have heard of people on HT doing this) that one of the lines are supposed to be kept open, it is for a boost controller. Am I right? Would that cause the Harely type sound?
Thanks again for the quick replies.
Old Nov 4, 2001 | 02:36 PM
LsTurbo91's Avatar
oh man I think i know what that is, Did he hook up a line going from the intake manifold to the side port of the wastegate?
Old Nov 4, 2001 | 04:10 PM
bigTom's Avatar
generally... the top port is for a bc and the side one is for a vaccumm line to let the wg know when to open
turboorsupercharger
Jul 26, 2008 06:29 AM
dezerte
Mar 8, 2007 06:57 AM
hotimportcrx
May 21, 2005 03:10 PM
fipracing_com
Aug 15, 2004 12:55 AM
wade
May 14, 2004 02:04 PM
