Turbo Downpipe Question
Old Mar 17, 2004 | 03:55 PM
Soccerking3000's Avatar
Default Turbo Downpipe Question
i recently purchased a trubo and downpipe mfrom another person here on the forums and was wondering if the downpipe was a/c compatible, can i tell w/o putting it in my car??? or will i just have to see cause i don't want to start installing everything and then finding out that i need to make a new downpipe.
Old Mar 17, 2004 | 04:18 PM
RyanEJ8's Avatar
Default Re: Turbo Downpipe Question (Soccerking3000)
Is it a 2.5 or 3" downpipe? The downpipe generally has to be 2.5" until it gets past the A/C compressor, then it can be flared out to 3". If it is 3" all the way it probably won't fit.
Old Mar 17, 2004 | 04:32 PM
Default Re: Turbo Downpipe Question (RyanCivic2000)
it is 2.5 inch pipe i will get a pick of it in a few minutes, it is also a 14b turbo and it seems like it comes out the left side(as if yo were looking at the front of the car at the engine bay) thats the other side than the compressor isn't it?? well here are the pics
Modified by Soccerking3000 at 8:55 PM 3/17/2004
Old Mar 17, 2004 | 04:33 PM
RyanEJ8's Avatar
2.5" should be fine with A/C.
Old Mar 17, 2004 | 05:17 PM
will there be any problems since the downpipe comes out the opposite side?
Old Mar 17, 2004 | 06:32 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">will there be any problems since the downpipe comes out the opposite side?</TD></TR></TABLE>
It doesn't come out on the A/C compressor side?
EDIT: I didn't see the pics a second ago.
Modified by RyanCivic2000 at 10:43 PM 3/17/2004
Old Mar 17, 2004 | 06:40 PM
Snail Tuning's Avatar
from looking at those pics i don't think u will be able to keep your a/c, because the compressor side (cold side) of the turbo will be sitting right where your a/c compressor will be. and 2nd their would be no place to fit an air filter.
if u were to reverse the position of the turbo. so the dp was on the driverside. u would stand a chance. but u would need to reweld everything.
Old Mar 17, 2004 | 06:59 PM
Default Re: Turbo Downpipe Question (bmcc72)
could i reroute the the intake tube with a sharp mandrel bend and clear a/c compressor? have it go down and to a fliter there
Old Mar 17, 2004 | 07:18 PM
anyone else have any input on this?
Old Mar 18, 2004 | 07:50 AM
iam7head's Avatar
Just to be honest, no body knows for sure. Well, i assume you paid the downpipe and everything already.
I would say try to put it on and see if it will fit.
I mean it might clear the ac line just fine(altho' i am kinda skeptical)
Old Mar 18, 2004 | 12:09 PM
CRX T-Si's Avatar
Default Re: Turbo Downpipe Question (iam7head)
From the pics you provided it looks like your doing the HF manifold with adaptor plate. This kind of setup almost everyone gets rid of their A/C cause they are on a budget and the position of the Manifold with the turbo connected does not allow A/C.
Then your DP is coming from the passenger side so I am 100% sure you cannot fit that with A/C.
You will have to face the compressor side to the passenger or else you won't have A/C.
Bottom line you ain't gonna have A/C with that DP setup.
Old Mar 18, 2004 | 02:27 PM
Default Re: Turbo Downpipe Question (CRX T-Si)
ya thgats what i thought i am just going to cut it right below where the wastegate pipe and the actual downpipe come together and flip it aorund 180º thats should work shouldn't it
2000SICVC
Nov 27, 2010 07:28 AM
EdSales
Dec 27, 2009 10:15 AM
quikB18B
Aug 18, 2003 07:35 AM
BorderM3
Jan 20, 2003 08:46 PM
Andrew 825SM
Jun 20, 2002 11:59 PM
