Turbo Delemia
Old Feb 8, 2006 | 01:41 PM
cotorresgee's Avatar
Default Turbo Delemia
For you experienced guys that have had experience with the sc-61 gt35r or 60-1 what would u reccommed I have a gsr bottom end with b16 head neptune and 880 percision injectors..And don't say gt35r cause its a ballbearing I am trying to do this as economical as possible looking ot put down between 400-500 whp..THX
Old Feb 8, 2006 | 01:50 PM
liam821's Avatar
25 Year Member
Default Re: Turbo Delemia (cotorresgee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cotorresgee &raquo;</TD></TR><TR><TD CLASS="quote">For you experienced guys that have had experience with the sc-61 gt35r or 60-1 what would u reccommed I have a gsr bottom end with b16 head neptune and 880 percision injectors..And don't say gt35r cause its a ballbearing I am trying to do this as economical as possible looking ot put down between 400-500 whp..THX </TD></TR></TABLE>
If keeping the price low and with a power target of 500whp, the SC61 is your turbo. There is a few of them which are all very similar and similar price. PTE SC61, Innovative GT61, PHXTURBO Blowzilla just to name a few. They are all around $700-900.
liam
Old Feb 8, 2006 | 06:30 PM
Default Re: Turbo Delemia (liam821)
Cool Thx bro do you know much between the pte61 or the other you mentioned..and is the spool time still about the same on the different brands?
Old Feb 8, 2006 | 06:32 PM
Turbo-charged's Avatar
GT35r is the obvious choice. its a no brainer in my opinion
Old Feb 8, 2006 | 06:40 PM
TURBOELEMENTS IKE's Avatar
Default Re: Turbo Delemia (Turbo-charged)
check out our t3/t61 "blowzilla" with the gt35r compressor wheel and btw i put down over 310hp with a t3/t04e 57 trim on 13 lbs stock 1.6L block.
Old Feb 8, 2006 | 07:37 PM
PrecisionH23a's Avatar
I say SC61. Cheap, efficient, proven.
If you have more money go with the gt35
Old Feb 8, 2006 | 08:38 PM
KeyserSoze's Avatar
Default Re: Turbo Delemia (PrecisionH23a)
If your looking for a good turbo to hit that mark and are on a budget, I would suggest a holset hx35. There is a whole thread here dedicated to holsets turbos, check it out it may be a viable option for you. GL.
You can find the comp map for the turbo in the holset thread, but @ 25psi (2.7pr) the compressor flows 55lb/min @ 65% efficiency. Plenty for what you are looking for.
Old Feb 9, 2006 | 11:23 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cotorresgee &raquo;</TD></TR><TR><TD CLASS="quote">Cool Thx bro do you know much between the pte61 or the other you mentioned..and is the spool time still about the same on the different brands?</TD></TR></TABLE>
They are all very similar. GT40/GT35r (same wheel) compressor wheel stuffed into either an E or S cover. T350 exhaust side in a t3 housing with your choice of size. The PTE and Innovate both run custom exhaust housings which they said make more power, while others use real Garrett pieces. Innovative can uses Inconel wheels which help for high temp durability.
They are all within 5% of each other IMO and all offer very similar spool times. Personally id pick somebody that you trust buying from.
I bought my turbo from Ken@phoenixturbo.com (you can PM him here on honda-tech), he was super helpful and answered all my questions.
liam
88_lsvtec_hatch
Jul 17, 2006 07:52 PM
sivortech
Jul 30, 2005 02:26 PM
onesikcivic
Jun 29, 2005 09:23 PM
tony n.
Apr 24, 2005 12:11 PM
