turbo DA Integras
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH »</TD></TR><TR><TD CLASS="quote">Who here still retains p/s and a/c?
I still have the power steering and a/c since its my daily driver. U know how hot it gets here in so cal during the summer
anyone deal with a 14b/logstyle with ps/ac?
ill be tackling the fitment soon but any tips would be helpful since i cant park in the garage or even in front of it. i gotta do most of the work at friends' homes
pics of agen2integra's car
standard engine bay shot
2 pics of where the manifold was re welded because it cracked after 3 months of use.
and finally a pic of the x bar our friend welded in the trunk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by internet izzay »</TD></TR><TR><TD CLASS="quote">pics of agen2integra's car
lol. where are the braces for the mighty autochrome?
I had both AC and PS on my B16- new setup, I'm losing both. Was using the DRAG2 manifold. This isn't the best engine bay pic, but you can kind of see how the piping runs all on/through the passenger side.
heres mine, now now it has black 15inch rota slip streams and an OEM hood and fucked front bumper cuz of a little wreck
Has a b18b head,(stock), b18a block-bored 20 over, JE 9:1 pistons, eagle rods, arp rod bolts and head studs, hondata s200b, skunk2 intake manifold, rc 440s, hondata intake mani. gasket, custom made manifold by me and my friend, 3 inch exhasut, 38mm tial wastegate, TurboXS BOV, custom made IC pipe by me and my friend, 6 puck clutch, 9LB flywheel, Innovative T3/T04e turbo, 50 trim, stage 5 wheel upgrade (its huge), .63 AR, with a 360 degree thrust bearing upgrade. Dyno soon
(Has a b18b head,(stock), b18a block-bored 20 over, JE 9:1 pistons, eagle rods, arp rod bolts and head studs, hondata s200b, skunk2 intake manifold, rc 440s, hondata intake mani. gasket, custom made manifold by me and my friend, 3 inch exhasut, 38mm tial wastegate, TurboXS BOV, custom made IC pipe by me and my friend, 6 puck clutch, 9LB flywheel, Innovative T3/T04e turbo, 50 trim, stage 5 wheel upgrade (its huge), .63 AR, with a 360 degree thrust bearing upgrade. Dyno soon
turbo da teg are the ****....
i still on stock b17 motor, with 5 psi everyday driving and 10psi when i turn it up, which i turn it up all the damn time . my car has 162k on it, it was strong but it smokes now and cuts out and off. time for a BIG *** TURBO BUILD....
Can someone post pics of some DA's with a front mount behind the factory grill and one with out it. i want to see which one looks better.
Modified by DA Rooki3 at 5:12 AM 2/27/2004
Modified by DA Rooki3 at 5:17 AM 2/27/2004
i see that many of you guys are running the smaller radiators....is that safe, considering that the DA uses a big radiator? Wouldn't you use a bigger radiator if you were going turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 »</TD></TR><TR><TD CLASS="quote">i see that many of you guys are running the smaller radiators....is that safe, considering that the DA uses a big radiator? Wouldn't you use a bigger radiator if you were going turbo?</TD></TR></TABLE>
I tried using a civic half size radiator and it over heated. Now I'm using a CRX full size half thin radiator and its working fine. Space is a big issue on our turbo DAs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yimmy »</TD></TR><TR><TD CLASS="quote">Nice car Joseph. Can we get some specs on it.</TD></TR></TABLE>
stock b16 @ 8.5 psi
Greddy 18g turbine and manifold
custom intercooler piping
Modified by JOSEPH at 9:26 AM 3/4/2004
Modified by JOSEPH at 9:28 AM 3/4/2004
stock b16 @ 8.5 psi
