Turbo D16Z6
we hit 15 lbs a couple of times with alot of fuel and stock internals on my buddies z6.. threw every code in the book and clipped the 310's tho lol
yeah, my car has hit 15 a few times, but i run 10psi daily on stock internals, with a decent fuel system
yeah, my car has hit 15 a few times, but i run 10psi daily on stock internals, with a decent fuel system[/QUOTE]
Could you post the set up that you're running and maybe some pics of it.
Thanks
Troy
Thanks
Troy
Thanks
Troy
ford probe turbo
homemade piping
drag II fmic
dragII fmu w/8:1 disc
nos 255lph in-line pump
rc 310's
[Modified by Zit, 7:58 PM 8/14/2002]
the little ihi's aren't worth **** as far as i'm concerned...they make good boost on sohc's, but they fun out after about 6600rpm...and they are a dime a dozen a junk yards
thanks
BTW Love the "junk yeard" turbo setup
OK i think i can...
if the car isnt running by next week...im going to burn it!!!
i hate my car... beat that
I'm running stock, 4psi, boost with my GReddy kit on my D16Z6. Won't go over 6psi on stock internals. Plus I'm not using an IC so I can stay in a sleeper mode.
the fact you are not using a IC won't give you a "Sleeper mode"
Look at Sir kid setup, this is a sleeper, got max performance without having to sacrifice look.
then just get an intercooler mounted Inside the front bumper behind a grill or anithing else, Other think you'r a ricer cause you got cheap *** grill in front but you can kick their *** anytime !!
So what would you boost on the following:
a6 block
z6 head
blockguard
LS rods
JEpistons .020 over (z6 compression)
Daily?
And for those times when you need a little more boost?
a6 block
z6 head
blockguard
LS rods
Daily?
