turbo for d16z6
Old Apr 12, 2006 | 09:06 AM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default turbo for d16z6
here's the setup, looking for a good size turbo. i'm new to the FI forum..so bare with me.
d16z6 115kmiles
new oem head gasket
arp head studs
tuned on crome
i'm just looking for the best size turbo that wont be over kill, some have told me t3/t4 50trim, some have told me t3/t4 57 trim and some have told me straight t3 48trim.. any other options? what would be the best turbo suited for my application? thanks in advanced for my noobie post.
Old Apr 12, 2006 | 09:10 AM
T3T495GSR's Avatar
Default Re: turbo for d16z6 (iHOPEyouCHOKE)
t3 super 60 , oh by the way, how is your training / dieting coming along?
Old Apr 12, 2006 | 09:14 AM
* B A N N E D *
Default Re: turbo for d16z6 (T3T495GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">t3 super 60 , oh by the way, how is your training / dieting coming along? </TD></TR></TABLE>
i'm not sure that i'd have enough money for the t3 super 60. i haven't hit the gym in awhile. i'm dissapointing myself lol
Old Apr 12, 2006 | 09:20 AM
AbitAvenger's Avatar
whats your budget bro? what car did you get?
Old Apr 12, 2006 | 09:23 AM
* B A N N E D *
Default Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">whats your budget bro? what car did you get?</TD></TR></TABLE>
del sol. my budget is around 1700. maybe more. maybe less. ssac woot.
Old Apr 12, 2006 | 09:26 AM
nonvtecD's Avatar
48/42 T3 will spool real fast, a 48/60 T3 would be perfect, full boost at 3500 all the way to redline, thatd be my pick, and you can pick them up on the classifieds for $250-$300.
Old Apr 12, 2006 | 10:00 AM
nota-eg's Avatar
Default Re: (nonvtecD)
Not sure if I just can't find them or if you didn't post them, but what are you power goals?
Old Apr 12, 2006 | 10:59 AM
* B A N N E D *
Default Re: (nota-eg)
i just want a 'fast' daily driver thats semi reliable. what do you guys think about a d16z6 with 94k miles on it, with these mods: without the head gasket and head studs will it still hold up to 9 pounds if its tuned good? and yes i know its on an FMU and will come off and would get Crome.
garrett t3 .63/.48
drag manifold
extreme machines fmic
greddy type rs bov
2 1/4" piping to 2 1/2" charge pipe
b&m fpr
autometer phantom boost gauge
2 1/4" dp
all couplings and clamps
car is untuned, boosted for a month
exedy oe clucth/w pp (will come with stage 2 fidanza clutch on the side)
ngk plugs and wires(heat range 7)
pacesetter catback with skunk2 axelback
Old Apr 12, 2006 | 11:47 AM
nota-eg's Avatar
Default Re: (iHOPEyouCHOKE)
As far as a "fast DD" I'm using a TD04 14G. It's off of like a Talon or 3000GT. It's bigger than a WRX turbo, but it's still small. Crazy spool up.
Right now I'm running 15psi on my stock Z6 w/ ARP headbolts and 310cc injectors. Ran 13.7 on street tires.
I like it because it's small, spools quick, and has good low end. Not to mention when I'm at the track you can only hear the turbo screaming.
Old Apr 12, 2006 | 11:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">As far as a "fast DD" I'm using a TD04 14G. It's off of like a Talon or 3000GT. It's bigger than a WRX turbo, but it's still small. Crazy spool up.
I like it because it's small, spools quick, and has good low end. Not to mention when I'm at the track you can only hear the turbo screaming.</TD></TR></TABLE> what i'm doing.
How close are you injectors to maxxing out? Any idea on how much power your putting down?
Old Apr 12, 2006 | 12:14 PM
beerbongskickass's Avatar
If your keeping the motor stock a t3 60/.48 would be perfect (that's what I use). I would not go any smaller than that at all (small turbos fuking blow ***), but you could probably go a little bigger.
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote"> what i'm doing.
How close are you injectors to maxxing out? Any idea on how much power your putting down?</TD></TR></TABLE>
Right now with the map I'm on they're probably close to about 75 or so duty cycle running a smooth 12-12.5 AFR. It's still semi-tuned w/ uber.
I'll be swtiching completely to Crome as soon as I get my laptop datalogging setup.
I'd like to think I'm putting down around 200whp since I'm able to run 13.7-13.8 on street tires with 2.4 60 fts.
blks2k3
Jul 24, 2006 11:01 AM
srg
May 2, 2006 09:15 AM
mr.roboto
Feb 27, 2006 08:04 AM
Timmay
Mar 16, 2005 08:02 PM
gtcali
Jan 23, 2002 01:52 PM
