turbo d16 breaking up problems
Old Apr 19, 2008 | 06:35 PM
jdmsohc2nr's Avatar
Default turbo d16 breaking up problems
okay. So i just got tune the other day. we only could bring the boost up to 9.5 psi because i had a bad alternator and the car was miss firing at about 6,800 rpm's. So he set me rich, told me to change the alternator. Now one problem i know of is that we have the alternator all the way to the firewall and yet the timing is still retarded a bit. i am assuming when they milled the motor it is causing this. (solution- adjustable cam gear or make the slits on the alternator bigger so i can move it back more). So i came home, put a new alternator in, and cranked the boost to 15psi wit a manual boost controller and it still seems to be breaking up. So i put my 15psi spring in the wastegate and now is breaks up at a even lower rpm. I don't know what the [freak] to do anymore. i'm getting really mad because i have had problems like this last year to and i finally saved and got retuned and still. P.s car is built and has all correct fuel supplies to handle this power.
Old Apr 20, 2008 | 04:31 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turbo d16 breaking up problems (jdmsohc2nr)
setup?
ems?
map sensor?
Old Apr 20, 2008 | 06:31 AM
jdmsohc2nr's Avatar
Default Re: turbo d16 breaking up problems (boostedcivicsir)
d16z6. srp pistons, scat rods, stock head, dsm 450's ectune, 9:1 compression B&M FPR 50psi fuel pressure. 3 bar map sensor
Old Apr 20, 2008 | 08:59 AM
97grnrs's Avatar
u prob mean the distributor.. and messing with the timing without knowing where to put it can blow that motor easy. tuner should know what to do . .
Old Apr 20, 2008 | 09:40 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsohc2nr &raquo;</TD></TR><TR><TD CLASS="quote">d16z6. srp pistons, scat rods, stock head, dsm 450's ectune, 9:1 compression B&M FPR 50psi fuel pressure. 3 bar map sensor</TD></TR></TABLE>
i dont see the ems listed??
Old Apr 20, 2008 | 09:56 AM
Newt Dog's Avatar
Default Re: turbo d16 breaking up problems (mike93eh2)
ectune
Where is zex_cool when you need him! lol
Old Apr 20, 2008 | 09:59 AM
mike93eh2's Avatar
Default Re: turbo d16 breaking up problems (Newt Dog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newt Dog &raquo;</TD></TR><TR><TD CLASS="quote">ectune
Where is zex_cool when you need him! lol</TD></TR></TABLE>
oh, i guess the commas in the wrong spots threw me off..
im sure he is on his way.
Old Apr 20, 2008 | 10:42 AM
tealegg's Avatar
what do you have the plugs gapped at?
Old Apr 20, 2008 | 11:08 AM
welfarepc's Avatar
i am sure your problem lies in the fact you think your alternator controls your timing.
if you are having ignition break up, i would suggest replacing the plugs, wires, and dizzy cap. also make sure your dizzy has the electro shielding still inside
and set your timing with a timing light and your service jumper jumped.
Old Apr 20, 2008 | 06:12 PM
jdmsohc2nr's Avatar
Default Re: (welfarepc)
No one ever said that the alternator controls timing. But when your alternator is not putting the proper voltage out than this creates a problem. Problem being that the car may not be getting the right amount of power to the ignition. and ignition and spark is something that you the right amount of. The plugs i have used in the car last year and are the plugs i was told to use by the tuner. i never gap them because they come pre gapped but i did notice he lowered the gap at the dyno.
Old Apr 20, 2008 | 06:19 PM
count me out's Avatar
* B A N N E D *
Default Re: (jdmsohc2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsohc2nr &raquo;</TD></TR><TR><TD CLASS="quote">No one ever said that the alternator controls timing. But when your alternator is not putting the proper voltage out than this creates a problem. Problem being that the car may not be getting the right amount of power to the ignition. and ignition and spark is something that you the right amount of. The plugs i have used in the car last year and are the plugs i was told to use by the tuner. i never gap them because they come pre gapped but i did notice he lowered the gap at the dyno.</TD></TR></TABLE>
you said that you have the alternator all the way to the firewall and your timing was still retarded.
i think you need to figure out what the [freak] youre talking about before trying to get help because people who are actually knowledgeable will go onto the next thread when you say the alternator affects timing.
Old Apr 20, 2008 | 06:50 PM
cbustuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">i am sure your problem lies in the fact you think your alternator controls your timing.
and set your timing with a timing light and your service jumper jumped. </TD></TR></TABLE>
I would try those suggestions.When my car was breaking up it turned out to be the plug gap was too wide and then I was too rich in the higher rpms.
Old Apr 20, 2008 | 07:18 PM
jdmsohc2nr's Avatar
Default Re: (cbustuner)
my bad. i meant the dizzy. anyone with half a brain would figure out that obviously meant the dizzy. having the alternator all the way to the firewall makes absolutley no sense. i know i wrote it but it was a f'in typo christ. bunch of know it all around here. Thanks to those who have helped me out.
Old Apr 21, 2008 | 12:55 PM
darkchiller23's Avatar
same thing used to happen to me. i changed the plugs and the car ran great. also ps. go with some colder plugs like heat range 7's
boarding2008
Jul 3, 2011 10:10 PM
accord2nrz
Mar 17, 2008 05:49 AM
Boosted Chemist
Sep 11, 2005 07:24 AM
precord96
Feb 18, 2004 09:13 AM
