turbo on d15b2
Old Nov 23, 2001 | 08:21 AM
maximedx's Avatar
Default turbo on d15b2
what is the maximum psi to settings my turbo for the car runs great.i think that is around 8 to 12 psi.
Old Nov 23, 2001 | 09:46 AM
asnx6pac's Avatar
Default Re: turbo on d15b2 (maximedx)
On a stock d15b? If you want to blow the motor in a week.
Old Nov 23, 2001 | 08:15 PM
Mista Bone's Avatar
D Tranny Guru
2-3 psi max on puny 1.5L rods.
Old Nov 24, 2001 | 08:59 PM
DJ0820's Avatar
Default Re: turbo on d15b2 (Mista Bone)
I hope your not serious. AbaZ from the CRX Resource ran like 10 psi street and 12 psi strip for like a month when he was trying to blow up his DX motor. Needless to say it finally went, with a rod through the oil pan. I *think* that all USDM 2g CRX/ 4g Civic D series rods are the same... And remember good tuning is key.
Later,
Derek
Old Nov 24, 2001 | 10:01 PM
WuShu's Avatar
New User
Default Re: turbo on d15b2 (DJ0820)
wrong place to ask bro, post it in the forced induction forum. But you can boost till your heart desires, it all depends on your fuel, if you got your fuel down perfect you can boost pretty high, liam(something) in forced inductions pushes about 15 psi on his d16, granted its a 1.6 but thats still really high for a stock motor. 1.5 rods are pretty tiny though but still with correct fuel you should be able to boost somewhat high, but this is something you should be doing on a dyno.
Old Nov 25, 2001 | 01:24 AM
Mista Bone's Avatar
D Tranny Guru
only lasted a month eh?
Most of us want a combo to last at least 3 seasons.
BTW you are wrong on a D rod info.
Grab a helms and you'll find out why.
Old Nov 25, 2001 | 02:39 AM
redteg1's Avatar
why not just go DOHC? you'll still be slow as ballz w/a turbo on that single cam. u can never get enuff power out those things
[Modified by redteg1, 11:39 AM 11/25/2001]
Old Nov 25, 2001 | 12:02 PM
DJ0820's Avatar
Did you notice that I said he was TRYING to blow his DX motor by running high boost? And you were wrong about the 2-3 psi maximum... Can I get some pictures of a DX rod next to an Si rod?
Do the MPFI swap and boost it 'till the cows come home.
Later,
Derek
Old Dec 4, 2001 | 11:34 AM
AbaZ's Avatar
I have tons of rods laying around my shop, the d16a6,d15b2,ZC and the z6 all have the same rod size, the journals could be a bit smaller on the b2 since the crank is alot smaller then the d16's, but the rod threshold is about the same as the a6. A well tuned a6 can handle 12psi no problems. I was doing an experiment with a b2 a few months ago to see how much it could really handle. I took it to the track and was running 13 psi, it ripped pretty hard for a dx motor. One night I was going out street racing leading the pack, I pegged it pretty hard, My speedeo was stuffed in my dash.. I let off then pucnhed it (putting a serious load on it) 0 to 10 psi in a few sec's and it let loose, 1 rod threw the pan and 1 out the block.. It was very funny, all the cars behind me got sprayed with oil.
With a MPFI swap, 440cc injectors running a Zdyne or any type of stand alone engine managment the b2 can handle some good boost..
RIP hah
Good luck Derek
Old Dec 4, 2001 | 02:16 PM
MNCRXSi's Avatar
On a stock D15B2, You better have MPFI done to it, after that has been done, I would feel safe running up to 6 PSI on there, and make sure you have enough fuel (eather using a Fuel Mangament unit or an ECU) and go from there.
Old Dec 4, 2001 | 05:25 PM
4G-CIVIC's Avatar
New User
Default Re: turbo on d15b2 (MNCRXSi)
I talked with a guy with a custom turboed d15b2 running 10 psi daily and hitting 13.7-13.9 on the track(even showed me time slips). He had standalone computer and a few other tuning tweaks but he said he had been running on the stock rebuilt for about 1/2 yr.
Personally I ran 190lbs of N2O total at 55-75 shot on a d15b2 and it lasted 9 months of hard driving. So people say the motors are weak but alot of people can tell you different.
However, maybe the majority of people blow their tbi dx motors and you just dont hear about them, so do your research.
Old Dec 4, 2001 | 05:49 PM
maximedx's Avatar
ok so what is the best psi to run my turbo on my d15 block for do not blown my engine. and how many hp can gain with this mods. your d15 have how many hp abaz.
thank you
Old Dec 4, 2001 | 05:52 PM
DJ0820's Avatar
What's up now?
Later,
Derek
Old Dec 4, 2001 | 11:05 PM
AbaZ's Avatar
Default Re: turbo on d15b2 (4G-CIVIC)
I was running 13psi at the track with my b2. The best time i could get was 14.0 @ 102mph.. The clutch was just a pyle of ****, I could easily see mid 13's with a decent clutch..
Curious does that guy live in the Northwest? does he go to SIR? I have never seen him down their.
Jeff
Old Dec 5, 2001 | 12:14 AM
Mista Bone's Avatar
D Tranny Guru
bearing journals are different sizes, as is ceneter to center length.
Old Dec 5, 2001 | 09:34 AM
liam821's Avatar
25 Year Member
Default Re: turbo on d15b2 (redteg1)
I am hoping for 12s on my stock motor sohc turbo!! I have run a best of 13.6 @ 105 on street tires..but that was at 5400 feet. I am hoping at sea level and more tuning i can pull it off...pretty sure i can!
12s with a stoch sohc...thats what its all about.
liam
Old Dec 5, 2001 | 02:11 PM
4G-CIVIC's Avatar
New User
Default Re: turbo on d15b2 (AbaZ)
AbaZ, They guy lives in Vancouver I think? I saw him in Bellingham one night, talked with him after he kicked my @ss racing.
[Modified by 4G-CIVIC, 11:12 PM 12/5/2001]
Old Dec 5, 2001 | 04:14 PM
AshlandSi's Avatar
If you D guys are tired of seeing this kind of crap posted, check this out:
http://pub34.ezboard.com/bhondadseries
All tech and don't have to deal with the haters.
JZs15
Feb 26, 2009 03:21 PM
lunaticracer21
Mar 10, 2007 10:28 AM
22psicrx
Jul 10, 2006 11:29 AM
my crx is rhd
Dec 27, 2004 12:59 PM
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
