Turbo Coolant Lines Idea
Old Aug 13, 2005 | 04:18 PM
Sketch_hs's Avatar
Default Turbo Coolant Lines Idea
So i got a new radiator that has the two extra fittings for what i guess is the Automatic Tranny cooler (?)
They are both on the radiator but can i run my turbo coolant feed/return two the fittings and be okay???
Old Aug 13, 2005 | 04:29 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: Turbo Coolant Lines Idea (Sketch_hs)
thats not going to work....the coolant flows in a direction IN the turbo then OUT. If you hook both of them up to that it's not gonna flow anywhere. Use the lines from your throttle body, you get a cooler TB and the lines are already there. good question though
Old Aug 13, 2005 | 04:34 PM
Sketch_hs's Avatar
so it won't work okay..
wait then how does the ATF cooler work if there is no flow??!
Old Aug 14, 2005 | 10:04 PM
2000psi's Avatar
Default Re: (Sketch_hs)
ATF is pumped in and out by the turbine inside the transmission. If you use the TB lines they are already set up to flow.
Old Aug 15, 2005 | 10:59 PM
Sketch_hs's Avatar
Default Re: (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">ATF is pumped in and out by the turbine inside the transmission. If you use the TB lines they are already set up to flow.</TD></TR></TABLE>
i had no idea
anything i can use those ports for or just block them off?
Old Aug 15, 2005 | 11:07 PM
2000psi's Avatar
you could use one as a return line for coolant coming out of the turbo....but you can't use both.
EJ8Squad919
Oct 19, 2012 03:57 PM
powerdbygarrett
Mar 13, 2009 10:53 AM
bambam
Apr 13, 2005 02:21 PM
nekkedR
Jan 14, 2004 01:19 PM
GruvyTune
Sep 6, 2002 05:09 AM
