Turbo Civiv problems!
Old May 25, 2006 | 12:56 PM
bitz95civ's Avatar
Default Turbo Civic problems!
I have a 95 turbo civic with a d16z6, and over the past few days it has been idleing wierd. When i come up to a stop and put it in neutral the rpm drops to 0 almost stalls and then fluctuates between 250-600. Today i was driving and I decelerated in second and then gave it gas again and it started jerking really bad and wouldn't let me accelerate unless i punched it. What is wrong with my car? Thanks for any help.
Modified by bitz95civ at 3:39 PM 5/25/2006
Old May 25, 2006 | 01:02 PM
eK9aT10pSi's Avatar
Default Re: Turbo Civiv problems! (bitz95civ)
sounds like a bad tune. what is ur setup?
Old May 25, 2006 | 01:05 PM
moores55's Avatar
Default Re: Turbo Civiv problems! (eK9aT10pSi)
x2. what kinda fuel mang. are you running if its and fmu then that could be your problem. i had the same thing till i started running crome.
Old May 25, 2006 | 01:19 PM
bitz95civ's Avatar
Default Re: Turbo Civiv problems! (moores55)
my setup is Turbonetics T3 turbo, intercooled, holley fuel pump, pro charger fuel management unit.
Old May 25, 2006 | 01:35 PM
cambopheonix56's Avatar
What ECU do you have? How much boost? Sounds like a bad tune. Run crome.
Old May 25, 2006 | 01:39 PM
JDMlyfestyle's Avatar
well your first problem is that FMU.. its really hurting you..
Get a real source of tuning.. Chipped p28 with some sort of program. id also recommend upgrading your injectors
Now go do a comrepssion and leakdown test to be sure there is really no internal damage. But the bad idle could be issued with a failing Map or TPS sensor.
Old May 25, 2006 | 01:57 PM
bitz95civ's Avatar
Default Re: (JDMlyfestyle)
i'm running only 6psi and i guess shes going in the shop in the morning
Old May 25, 2006 | 02:24 PM
Paprika's Avatar
not to hate, but waht's a civiv?
Old May 25, 2006 | 02:40 PM
bitz95civ's Avatar
Default Re: (Paprika)
well that was hating but now its fixed. so is it possible to go to a normal shop to check out the problem cause there are only a few shops that deal with turbos around me and they are booked full. Is there a chance its a simple problem?
Old May 25, 2006 | 03:01 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">not to hate, but waht's a civiv?</TD></TR></TABLE>
Civic.
Old May 25, 2006 | 07:17 PM
bitz95civ's Avatar
Default Re: (99FBPSi)
Just wondering but when I do take it to get tuned or take it to the shop, could I be causing damage by driving it?
Modified by bitz95civ at 8:59 PM 5/25/2006
Old May 25, 2006 | 08:03 PM
bitz95civ's Avatar
Default Re: (bitz95civ)
Just moved my car into the garage and it is running terribly. Sounds like a v8!
Old May 25, 2006 | 08:44 PM
lodo's Avatar
does it do it when its cold? or just when the engine is warmed up?
Old May 25, 2006 | 08:52 PM
bitz95civ's Avatar
Default Re: (lodo)
when its warmed up, but it runs rough when its cold.
Old May 26, 2006 | 09:44 AM
bitz95civ's Avatar
bump for answer
Old May 26, 2006 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bitz95civ &raquo;</TD></TR><TR><TD CLASS="quote">bump for answer</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">well your first problem is that FMU.. its really hurting you..
Now go do a comrepssion and leakdown test to be sure there is really no internal damage. But the bad idle could be issued with a failing Map or TPS sensor.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 &raquo;</TD></TR><TR><TD CLASS="quote">x2. what kinda fuel mang. are you running if its and fmu then that could be your problem. i had the same thing till i started running crome.</TD></TR></TABLE>
Old May 26, 2006 | 06:46 PM
oscarmayer's Avatar
when was the last time you change the plugs?
whata bout your cap and rotor?
Old May 27, 2006 | 12:48 PM
bitz95civ's Avatar
Default Re: (oscarmayer)
Well I don't really know..got the car a month ago, but the guy said he cleaned them often so they might be a bit worn out for the plugs.
Old May 27, 2006 | 12:52 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">when was the last time you change the plugs?
whata bout your cap and rotor?</TD></TR></TABLE>
ill second this. honda's go through caps/rotors/ plugs like changing underwear
replace that stuff. and also check your plug wires make sure they are in good condition.
Old May 27, 2006 | 03:39 PM
egrice's Avatar
tune up then tune.
Old May 27, 2006 | 03:42 PM
AbitAvenger's Avatar
Default Re: (egrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egrice &raquo;</TD></TR><TR><TD CLASS="quote">tune up then tune.</TD></TR></TABLE>
Old May 27, 2006 | 05:47 PM
akstunt600's Avatar
also check it over for a vccume line that may be dissonected
Old May 27, 2006 | 06:49 PM
Spec R's Avatar
Default Re: (akstunt600)
if it sounds like a subaru, then a cylinder or more arent firing....
Old May 28, 2006 | 08:11 PM
bitz95civ's Avatar
Default Re: Turbo Civic problems! (bitz95civ)
Okay so i found something interesting out today... My car runs perfect if i let it warm up before i leave. let it run for a couple minutes and it doesn't to anything wrong but i get it let it run for 30 seconds it does it.. wierd
Old May 28, 2006 | 08:23 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
check your oxygen sensor man. tha's what it sounds like to me if it's not those other issues. I bet it's the O2
