is this turbo cappable of 200hp
Old Dec 1, 2004 | 06:54 AM
kr's Avatar
kr
Default is this turbo cappable of 200hp
Well im beginning to build my backyard special turbo setup and i was wondering, is this turbo capable of reaching my 200 hp goal.
When will this turbo start to spool and when will it hit full boost?
I am not planning to build my block, but i am planning for a piggyback/standalone plus tuning&dyno /Unichip/. I am getting some dsm 450 injectors,and resistor pack.
What would you guys recommend me to upgrade or replace, good quality at a low cost will be the best.
This will be going into a 99 civic ex d16y8 approx 74.xxx mi. This car will be mainly street driven.
Hosted by imagestation
Old Dec 1, 2004 | 07:05 AM
SOHC_MShue's Avatar
Default Re: is this turbo cappable of 200hp (kr)
I've got a td04 on my y8. Estimating by my 1/4 times I assume I'm making around 190-200whp on 9-10psi.
Old Dec 1, 2004 | 07:54 AM
kr's Avatar
kr
Default Re: is this turbo cappable of 200hp (SOHC_MShue)
what is your setup? and what kind of engine management are you using.
Old Dec 1, 2004 | 09:09 AM
SOHC_MShue's Avatar
wrx turbo, hf manifold, dsm 450's, 255lph walbro pump, uberdata, zex 59300 cam, etc.
Old Dec 2, 2004 | 03:01 AM
kr's Avatar
kr
and what additional upgrade is recommended
Old Dec 2, 2004 | 06:29 AM
PrettyLude's Avatar
it will spool pretty quick, as no lag at all
Old Dec 2, 2004 | 06:48 AM
CivicEJ1's Avatar
it'll spool up at 2500-2800rpm but it'll max out at around 6500rpm.
good for a daily car.
Old Dec 2, 2004 | 07:09 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kr &raquo;</TD></TR><TR><TD CLASS="quote">When will this turbo start to spool and when will it hit full boost?
and what additional upgrade is recommended</TD></TR></TABLE>
mine takes forever to spool because the wastegate is messed up. It should spool very quickly though...,but mine doesn't hit full boost till after 4000 rpms . It still holds 10psi steady all the way to redline and doesn't drop off like a t25.
Old Dec 4, 2004 | 06:11 AM
kr's Avatar
kr
what kind of fuel pump do you recommend? As stated im not looking to make some crazy numbers 200-250hp is my goal.
And how hard is the installation on the fuel pump.
Old Dec 4, 2004 | 06:33 AM
USDM 4G VTEC's Avatar
u can get 200hp out of that , bu it will be like 10-11 psi
thats the DSM 15G turbo
looks like the 14B but its not
Old Dec 4, 2004 | 08:31 AM
JDMs1eeper's Avatar
Default Re: (USDM 4G VTEC)
You should be able to. Those turbos are pretty efficent
Old Dec 4, 2004 | 12:23 PM
iguano's Avatar
Default Re: (JDM S1eeper)
i am going to make the same setup as you but with a b18a1, stock internals, stock injectors, walbro 255 fuel pump, FMU vortech....... how many hp would i have????
thanks
Old Dec 4, 2004 | 12:41 PM
Tad's Avatar
Tad
hmm, I'm guessing it'd be harder to find a turbo NOT capable of 200whp than one that is.
and yeah, i'd bet this one is.
Dynastro
Apr 22, 2013 08:08 AM
iguano
Apr 17, 2006 07:39 PM
deeweezy187
Oct 24, 2005 09:27 PM
^MikeG
Sep 27, 2003 03:36 AM
Greg123
Dec 6, 2002 05:28 PM
