turbo bseries ideal temp
Old Nov 22, 2010 | 07:58 AM
kwah's Avatar
Default turbo bseries ideal temp
whats the ideal temp for a boosted b18c with sleeved block in idle mode?
Old Nov 22, 2010 | 08:11 AM
sp00led's Avatar
Default Re: turbo bseries ideal temp
I've got my fan set to cut on at 190F when below 30mph. I think the factory setting it cuts on right before 200F.
Old Nov 22, 2010 | 08:18 AM
E85B18's Avatar
With my current thermostat my car stays right around 185
Old Nov 22, 2010 | 08:24 AM
sp00led's Avatar
When cruising those ^^ are my temps but they go up quickly when at idle.
Old Nov 22, 2010 | 08:35 AM
[Ennis_D]'s Avatar
I have my fan set for 180 also and it seems to do well. I see higher temps when cruising and lower temps when at idle. I am running 50/50 w/ water wetter and I have checked to see if there is air in the cooling system but there isnt. Not sure why my temp fluctuations are the reverse of everyone else though....
Old Nov 22, 2010 | 08:53 AM
DelSolMarine's Avatar
under 200 at full boost... which means you should be well below 200 at idle... headgasket installation and head studs are vital in maintaining low ects so make assure you have upgraded head studsand they are properly torqued... while i am not using a fan shroud with my 13" pusher spal fan, if space is available, i would highly recommend using one...
Old Nov 22, 2010 | 09:43 AM
EddieCRX's Avatar
I was running some checks yesterday, ambient temps were 5*C
After a boosted run I was seeing ECT (*f) 185 to 188 with a slight rise on coast down till it settled back to (*f) 175 – 180
What did concern me was the IAT, at the ambient temps of 5*C what should I be looking for?
OK I understand factors such as IC etc play a role but realistically what’s a good IET for this ambient for street driven?
Old Nov 22, 2010 | 10:36 AM
sp00led's Avatar
I'm probably a terrible example because my filter/intake is behind my radiator/fan but I usually see ambient temp + ~20-30F. air/air fmic
Steeve_Civic
Sep 24, 2013 05:04 AM
BoostedEgHatchFl
Jul 16, 2012 04:16 AM
EKSedAndy
Nov 5, 2007 10:15 AM
Integra Integra
Dec 15, 2005 06:15 AM
ThisLittleSleepeR
Apr 6, 2005 09:35 PM
